Fom The Clubman Estate
#31
Posted 18 March 2010 - 12:28 AM
Whats that bike i see in the background?
#32
Posted 18 March 2010 - 01:04 AM
Nice work fella, getting on with it!
looks like a pushbike to me
projects looking good mate, keep at it
#33
Posted 18 March 2010 - 09:25 PM
Got a bit more done on the car today, cut some stuff, drilled some spot welds and got the other bin and the two vertical seat supports out. I would have got some shots with the Rover seats in the back but the spot weld drillbit is dead so I couldn't remove the hinge rail and set them in place.
#34
Posted 20 March 2010 - 02:46 PM
#36
Posted 26 March 2010 - 12:13 AM
Made the closing about the rear sub mounts and got it welded in.
Cut some rust out of the inner rear stiffener and welded a new piece in.
Made up a plate to cover the majority of the hole a tacked it in place.
#37
Posted 29 March 2010 - 10:50 PM
Started out like this.
Cut a plate to fill the first hole and made a template for the second.
Made the next plate.
Drilled some holes for spot welds and got it welded in.
Got the plate on the back spotted and butt welded.
#38
Posted 29 March 2010 - 10:57 PM
#39
Posted 30 March 2010 - 10:43 AM
#40
Posted 31 March 2010 - 09:23 PM
Did the welding on this bit myself, it could be better but I'm pretty happy with it.
Red oxided.
Sat in place.
Welded in.
Here's the rotten piece on the right and the new metal on the left. Don't you just love rust, I know I do.
Sat in place to check fitment.
And now welded, ground and linished. It still need a bit of work it getting there.
#41
Posted 31 March 2010 - 09:27 PM
Keep up the good work.
#42
Posted 02 April 2010 - 10:46 AM
Made a plate and got it welded in.
Ground and linished the welds so it's now smooth with the rest of the floor.
Cut a piece of steel to replicate the original flange that's still present on the other side.
And got it in place ready to drill holes for spot welding and mig along the bottom edge.
And while I had the linisher out I though I'd make a start on taking the weld down around the big plate in the floor.
I'll be giving the same treatment to the panel I made for the floorpan but grinding and linishing it from of the outside so it looks tidy from underneath.
Oh and I made the whole shell 5.9KG light by removing all the sound deadening from the floor.
Here's what I took out, the mug wasn't part of the floor though.
And heres what it looks like now.
#43
Posted 06 April 2010 - 06:32 PM
Holes drilled for sport weld.
Miged along the bottom and ground smoothish. It still needs a bit of work with the diegrinder.
Spot welds 'erm welded.
I also cut of a chunk of rust from one of the turrets, welded a new plate is and got it all ground and linished down.
Hole cut.
New metal welded in, ground down, and linished. (I forgot to take a picture of it welded)
Welded again from the other side to make sure it's uber strong.
#44
Posted 07 April 2010 - 07:40 PM
Started the morning a little worse than this.
Got to cutting.
Folded the first panel/plate and set it place to make sure the bends where right.
And they where so I trimmed it down and folded the last edge that will sport weld to the arch from the inside.
#45
Posted 09 April 2010 - 08:59 PM
Made a new end piece for the rear crossmember.
Sat the it in with the floor panel to check fitment.
Folded up a nice 90* piece for the back of the arch to spot to.
Went through a few different templates and made up this panel for the back of the arch.
And last but not least got the floor panel welded in and red oxided it.
So if I do decide to work tomorrow I should be able to the rest of this arch buttoned up and start to cut rust out of some other part of this thing.
