Fom The Clubman Estate
764 replies to this topic
#421 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 11 May 2012 - 08:23 PM
Nice fab work Tupers, how about either a stainless steel grille or a blacked out mesh grille??
#422 grahama
grahama
  • 2,442 posts
Posted 11 May 2012 - 08:59 PM
It was all going so well Tuppers, till the square headlights appeared, lol !!! Each to thier own I suppose, but I will reserve the right to change my mind when you have them in and it looks cool !!!
Graham
#423 _mini1000_
_mini1000_
  • 236 posts
Posted 11 May 2012 - 10:00 PM
really like the look of the quad headlights! very mean looking :)
will you be painting the headlight surrounds body colour?
#424 Tupers
Tupers
  • 4,142 posts
Posted 12 May 2012 - 04:51 PM
I quite like the idea of something like this.
They'll be body colour what ever that ends up being or maybe one of those new chrome spray finishes.
#425 sonikk4
sonikk4
  • 16,033 posts
  • Name: Neil
Posted 13 May 2012 - 02:42 PM
I think that would be a good look and different as well. It may take a bit of forming to get right but should look cool especially in body colour.
#426 benjy_18
benjy_18
  • 1,038 posts
  • Local Club: LSMOC
Posted 13 May 2012 - 03:30 PM
big fan of the headlights tupers!
deffinitly not keen on the ronals though, lets be honest, how good would this look on split slotmags???
#427 Tupers
Tupers
  • 4,142 posts
Posted 13 May 2012 - 04:38 PM
I've a actually been making some enquiries into getting a Rostyle centre put into a 6x10 hoop allowing me to pick the perfect offset for the car.
That said I am still rather attached to my 5x10 magnesium wheels. :highfive:
#428 Tupers
Tupers
  • 4,142 posts
Posted 16 May 2012 - 05:55 PM
My sort of shinny Maestro plenum turned up today. It'll need a bit of modification but I think it should look good on the back of a throttle body. :gimme:
#429 Tupers
Tupers
  • 4,142 posts
Posted 17 May 2012 - 05:58 PM
Another day at the grind stone, I got the plenum bolted up to my inlet manifold and used the centre of a HIF44 to stand in for the throttle body.
Then I decided I needed a mock up engine in the car to check fitment of a few things. This is where working at a Mini specialist comes in handy. :P
With the engine lifted in it seems I should be fine with the new plenum.
I also lent a Metro radiator in, this wont be the exact type I'm using but it'll do for now.
After nailing a few pieces of wood together as an impromptu mount I got the SC sat fairly close to where it'll end up.
The inlet to the plenum will need a little working to clear the clutch master cylinder but that's no problem.
The belt set-up should be fairly simple as well, the pulley nailed to the wood represents where the alternator will sit.
Ground clearance is one thing I'll be lacking, that's a AA battery.
#430 JustSteve
JustSteve
    Puke-Boy!!
  • 1,883 posts
Posted 17 May 2012 - 06:04 PM
Tupers, I am following your work, but never have anything to say! I think your work's great, although I'm not a fan of those ronal wheels... as you say, they make the side look as flat a s a pancake!
I'm not sure on the headlights either, but I'm sure they will look better in paint :D
Anyway, just wanted to say, keep it up! :thumbsup:
Edit: is there any chance you would be able to measure the ground clearance from floorpan/gearbox/front panel.
I've got no front panel to measure from and I have an idea.. but that's a secret :lol:
Edited by JustSteve, 17 May 2012 - 06:07 PM.
#431 Tupers
Tupers
  • 4,142 posts
Posted 17 May 2012 - 07:18 PM
Thanks Steve I'll get those measurements for you tomorrow, I hope your super secret front panel idea isn't the same as mine. O_O
#432 JustSteve
JustSteve
    Puke-Boy!!
  • 1,883 posts
Posted 17 May 2012 - 07:46 PM
Oh oh! Judging from what I've read from you in other posts, I think we may be building pretty much the same car! Give us a clue.. What're you thinking? :D
#433 grahama
grahama
  • 2,442 posts
Posted 17 May 2012 - 08:53 PM
The lights are growing on me, but not yet convinced !!
Right, what on earth is a plenum ??? Looks fab but just don't understand lol !!!
Graham
#434 benjy_18
benjy_18
  • 1,038 posts
  • Local Club: LSMOC
Posted 18 May 2012 - 06:03 PM
Just another word or an airbox graham, they do however differ slightly as they are usually for pieced induction use
Tupers, have you looked at the plenum to see if you nee to add a restrictive ring? I'm sure I read some of the guys on TM having problems with plenums without restrictor rings, unless your not using a carb and running some kind of throttle body? In which case, ignore me completely
#435 Tupers
Tupers
  • 4,142 posts
Posted 18 May 2012 - 06:45 PM
I'm thinking of something a little like this. :D
Don't doubt the lights they're amazing. :P A plenum is basically something that holds air at a positive pressure, in this case the high pressure air from my charger.
If I can stop blowing my wages at the start of every month I'll be running the Specialist Components 5 port engine management set-up, because I'm a tart. ^_^
