Fom The Clubman Estate
764 replies to this topic
#391 Tupers
Tupers
  • 4,142 posts
Posted 08 March 2012 - 09:34 PM
There was talk of chroming them but I think I'll save that for another car. ;D
#392 Tupers
Tupers
  • 4,142 posts
Posted 09 March 2012 - 08:27 PM
The front suspension's on as are my shinny 4 pot calipers.
I sat a jack under it to try and get it to ride height but I need to get it on the floor and an engine in it to get it right.
As it sits the tyres poke out by about 15MM and I'd imagine that'll go up a bit once it's at ride height.
The raised numbers on the wheels weight just clip the calipers but they can be moved in a bit to clear. You can also see the balljoint spacer on the bottom of the hub to bring to bottom arm back a better angle once the car is lowered.
#393 Tupers
Tupers
  • 4,142 posts
Posted 12 March 2012 - 09:30 PM
So for the first time since I bought the estate it's on wheels if only 2. :lol:
I think with a bit more camber I could get away with running 6X10s without arches.
The radius arms are on now, just need some Hi-Los.
And I went and got my MPI head from the sorting office. The threaded lugs on the thermostat end should make mounting the SC easier.
#394 Tupers
Tupers
  • 4,142 posts
Posted 15 March 2012 - 09:01 PM
Still no rear Hi-Los but I got some rear hubs and Mini Fins on so I could get it rolling.
I also pulled the cones out the front to get it at ride height. Anyone want some of my extra camber. :lol:
Under 80MM of ground clearance, wont be able to drive this anywhere.
#395 woodenman23
woodenman23
  • 299 posts
Posted 15 March 2012 - 09:04 PM
That's looking sweeeeeeeeeeeeeeeeeeeeeet
#396 grahama
grahama
  • 2,442 posts
Posted 15 March 2012 - 09:31 PM
Nice, that does look mean, love it !!
#397 ukshadow
ukshadow
  • 42 posts
Posted 16 March 2012 - 03:33 AM
low and mean lush
#398 mini-luke
mini-luke
    Postman Pat
  • 2,362 posts
Posted 16 March 2012 - 07:59 AM
Stick an engine in and drive it round like that :shifty:
#399 Tupers
Tupers
  • 4,142 posts
Posted 16 March 2012 - 10:01 PM
Thanks for the comments guys, it could be quite cool to leave it all Mad Max-ish but I thin it might be nicer to have some proper paint. :lol:
I thought I'd get back onto sorting the rear seat latches out this afternoon and seen a I'm doing something different with the side windows as well I pulled the old frames out.
I couldn't find any spare latches on the shelfs so I 'borrowed' a pair from my Dads Metro.
I'll have to build a bulkhead for them to bolt to and will be incorporating it into the new window frames. Shouldn't be too hard.
#400 Tupers
Tupers
  • 4,142 posts
Posted 19 March 2012 - 10:41 PM
I got the window frame/seat back brace under way. I made a section up in the folder and got it cut to size and cleco'd in. Just need to plan out where to bend the section in front of the seat now.
I also used the backing plates I started making earlier to make a pair of cups for the latches to sit into. These will become part of the window frame so you'll only see a small part of the latch.
#401 Tupers
Tupers
  • 4,142 posts
Posted 26 March 2012 - 09:27 PM
More work on the window frame/seat brace. I got folding and made the vertical brace for the seat catch.
After a bit of stretching I welded 3 returns onto the base to weld to the arch.
Then I tacked the vertical buttress to the window frame and added another return on the inside.
A few Celco's got it held in place while I finish the other side. It was a relief to see the seat folded up so nicely.
#402 grahama
grahama
  • 2,442 posts
Posted 26 March 2012 - 09:39 PM
Fantastic fabrication work as ever, don't know where you get your ideas from but keep thinking them up !!
#403 Tupers
Tupers
  • 4,142 posts
Posted 27 March 2012 - 07:31 PM
Cheers Graham, most of that was just designed on the fly to be honest. =]
#404 davej
davej
    Kelly Jones
  • 985 posts
Posted 28 March 2012 - 11:24 AM
Fantastic work and a brilliant idea, hats off to you.
#405 benjy_18
benjy_18
  • 1,038 posts
  • Local Club: LSMOC
Posted 28 March 2012 - 05:53 PM
yeah i suppose it looks alright!
when are you coming to help with mine then? aha
Ben
    Bing (1)
