Fom The Clubman Estate
764 replies to this topic
#376 Tupers
Tupers
  • 4,142 posts
Posted 20 February 2012 - 10:33 PM
I managed to pop down for a bit this evening to do a bit more one FOM. I had hoped to be down all day but had to cover for someone at my other job. :angry:
I crawled back under the front and finished off plug welding the toe board plate in, ground the excess down and whacked some primer on.
I also started on the reinforcing plate for the top the exhaust tunnel that internal **** mechanism will sit on.
This my brothers internal shifter that I'll be replicating for the estate.
#377 Andrew O
Andrew O
    Previously known as Andrewo330.
  • 1,425 posts
Posted 20 February 2012 - 10:36 PM
Looking good, what's the benefit of having a internal shifter if you don't mind me asking ?
#378 george91
george91
  • 883 posts
Posted 20 February 2012 - 10:45 PM
Its for better ground clearance on lowered cars, it allows you to tuck the exhaust up in tunnel. Looks good by the way. :)
#379 grahama
grahama
  • 2,442 posts
Posted 20 February 2012 - 10:49 PM
It does indeed look good, as ever. Great fabrication work all through this project, keep it up.
Graham
#380 Tupers
Tupers
  • 4,142 posts
Posted 20 February 2012 - 11:40 PM
As George said I'm using the internal shift mechanism to gain a little more ground clearance and save it from getting smacked as I'll be running about 3" for the tarmac.
#381 ukshadow
ukshadow
  • 42 posts
Posted 21 February 2012 - 09:29 AM
the internal remote out of your brothers car looks solid mounted is that true im asking as i have 1 i removed from a van which was mounted with rubbers to allow for any engine movement and when i finally get around to it i was going to fit it into mine.
#382 Tupers
Tupers
  • 4,142 posts
Posted 21 February 2012 - 09:52 PM
Yes his and mine are both solid mounted as well as having extra steadies on the engines to stop them moving.
I have seen some rubber mounted internal linkages but then you need to keep both the shifter rod and the stabiliser rod going to the gearbox which I've never thought look very nice.
Edited by Tupers, 21 February 2012 - 09:54 PM.
#383 Tupers
Tupers
  • 4,142 posts
Posted 23 February 2012 - 01:17 AM
Got back down again this evening and started by seam welding the reinforcing plate to the tunnel.
I took a little inspiration from Matts mount and came up with this.
Added a nice swaged hole at the front for the shift rod to come through.
It sits quite nicely in the car slightly further back that standard and obviously about 3 inches higher up.
#384 Tupers
Tupers
  • 4,142 posts
Posted 23 February 2012 - 11:26 PM
I got a seat and column back into FOM this afternoon before getting the gear stick where I liked it and tacking the mounts in place. On the final build I'll be using a start style gear stick not a quick crunch though.
I also had a little play with the shrinker/stretcher + hole swager and started making the rear section for my '69 Camaro SS style bonnet bulge.
The bulge will be 3CM higher than the scuttle and overlap it by another 3/4CM while tapering from 48CM wide at the back to 34CM at the front.
Edited by Tupers, 23 February 2012 - 11:29 PM.
#385 leaky
leaky
  • 6,890 posts
Posted 24 February 2012 - 12:15 AM
Love that shifter! You done a good job with that.
#386 Tupers
Tupers
  • 4,142 posts
Posted 25 February 2012 - 12:00 AM
Thanks leaky, I've seen it done a few other ways but I'm rather fond of mine. =]
I got the shifter brackets welded in this afternoon and did most of the reinforcing plate for the N/S toe board but no pics as it's just the same as the O/S.
#387 Tupers
Tupers
  • 4,142 posts
Posted 25 February 2012 - 07:51 PM
Had a bit of spare time after lunch so I popped down and finished welding the toe board pate in. I don't think they'll be going anywhere in a hurry. :lol:
#388 Tupers
Tupers
  • 4,142 posts
Posted 06 March 2012 - 06:51 PM
I got the final smoothing work done on the radius arms done yesterday. I used a 60 grit flap wheel then a 100 grit disc on the linisher and finally a soft scotch brite disc. Now they just need etch primer, lots of high build and loads of flatting.
I also bolted my top arms on and pulled my fancy bottom arms and tie bars out ready to get the front rolling.
#389 george91
george91
  • 883 posts
Posted 07 March 2012 - 11:41 AM
Nice work, i think you should just lacquer the radius arms, so shiney haha.
#390 ukshadow
ukshadow
  • 42 posts
Posted 07 March 2012 - 04:04 PM
i agree it would look cool
