Fom The Clubman Estate
764 replies to this topic
#346 Tupers
Tupers
  • 4,142 posts
Posted 04 February 2012 - 10:51 PM
Thanks Holly, I'm sure Stitch'll be fine. I could have had Fom on the road in 6 months but I keep getting carried away with the mods. :lol:
#347 Tupers
Tupers
  • 4,142 posts
Posted 06 February 2012 - 07:02 PM
Last night a started drawing up ideas of how I'm going to set-up the belts and build the outlet manifold fro the SC.
I got the solid mounting to the front of the frames sorted.
The front mounts have been moved up by 5MM to match the tower spacers. The small spacer between the frame and front panel will be replaced a larger one welded to the frame when it's finished.
I also got a little over excited and bought one of these from DSN Classics. It's a little premature but it's also very shinny and pretty. :kiss:
#348 benjy_18
benjy_18
  • 1,038 posts
  • Local Club: LSMOC
Posted 06 February 2012 - 08:35 PM
chris, what is the timing cover like? im looking into getting one of these once i need it
#349 Tupers
Tupers
  • 4,142 posts
Posted 06 February 2012 - 09:29 PM
I only ordered it this morning so I wont know until tomorrow or Wednesday depending on how quick the post is. :P
#350 benjy_18
benjy_18
  • 1,038 posts
  • Local Club: LSMOC
Posted 06 February 2012 - 09:31 PM
oooooooooo i think im more excited than i should be considering its not coming to my door!
#351 warning634
warning634
  • 489 posts
Posted 06 February 2012 - 09:56 PM
Outstanding!
Just read through your build and you have done such an amazing job, your metal work and ideas are just mind blowing, great skills.
Can't wait to see more of this :)
Kevin
#352 Tupers
Tupers
  • 4,142 posts
Posted 06 February 2012 - 11:03 PM
Thanks Kevin, I've still got plenty of ideas left for this one and another 100 other cars. :lol:
#353 Tupers
Tupers
  • 4,142 posts
Posted 08 February 2012 - 09:24 PM
Look at the shinny shinny. :D
A very comprehensive kit from DSN classics, they even sent thread lock. =]
#354 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 08 February 2012 - 09:38 PM
That as they say is lush!! nice bling there bud.
#355 Tupers
Tupers
  • 4,142 posts
Posted 08 February 2012 - 11:40 PM
You've not been listening to us kids talking again have you. :lol:
It is indeed a nice bit 'o' bling. The mega beefy alternator mount and extra holes for the trigger wheel senor should come in handy when I come to making the brackets to lower the alternator.
#356 Tupers
Tupers
  • 4,142 posts
Posted 10 February 2012 - 09:54 PM
Having sort 4 of the 6 subframe mounting points I moved onto the toe board today. I had planned to cut down a set of fabricated steel ones but decided that it would be easier to start from fresh and make my own.
Starting with these cut from 3MM steel.
After a little trimming I got it all bolted/clamped together.
I tacked them in situ and then took them to the work bench to finish welding. Not one of my best efforts but they're strong and will have a small gusset added as per to stock replacements. I was quite surprised at how different they ended up compared to the originals.
#357 bcjames
bcjames
  • 2,728 posts
Posted 10 February 2012 - 10:04 PM
Nice work on the mounts, top fab skills as ever! They do look different to the others, but hey if they fit!
That DSN cover is incredibly nice. It's a good job they don't make one for an MPi else I think my wallet would be a little lighter by now. I'm impressed by the kit that accompanies it, very comprehensive.
#358 leaky
leaky
  • 6,890 posts
Posted 10 February 2012 - 10:12 PM
Good work as ever. I do love this thread! Its gonna be a mean estate when its done. Did I read somewhere you are planning on making the engine sit a little higher? How you planning on doing that?
#359 benjy_18
benjy_18
  • 1,038 posts
  • Local Club: LSMOC
Posted 11 February 2012 - 05:45 PM
chris, ive been thinking abotu you raising your subframe and had a thought! is the steering rack not going to hit the subframe? or are you planning something for that already?
#360 Tupers
Tupers
  • 4,142 posts
Posted 11 February 2012 - 07:22 PM
There's actually a rack bolted on there now, I'd say there's about 1/2MM clearance between the rack and frame. I did contemplate bolting the rack to the frame but it would really serve no purpose.
I'm not set how I'm going to raise the engine yet but I'm thinking a thick spacer plate under each mount with high tensile bolts right the way through should do it.
