Fom The Clubman Estate
764 replies to this topic
#271 grahama
grahama
  • 2,442 posts
Posted 09 September 2011 - 06:24 PM
great work as usual. Are the holes on the subframe just to lighten it up or is it 'looks' you are after??
#272 Tupers
Tupers
  • 4,142 posts
Posted 09 September 2011 - 09:39 PM
the grinder: a mini owners most loved and used possession!
looks like all is going well chris, keep it up
Thanks Ben, the grinder is indeed a Mini owners best friend even if they do try chopping your fingers off from time to time. :lol:
They're more of a styling thing than anything else, I could probably save more weight by not eating my co co pops in the morning. :shy:
I grabbed a pair of hubs this afternoon and after stripping the studs and bearings out I gave them a scrub in the safety clean, went over them on the wire wheel and flicked some primer over them.
I also went over the radius arms again with the die grinder a cleaned up the harder to reach areas, now I just need make new hose mounts and spray them.
#273 skyblueads
skyblueads
  • 29 posts
Posted 20 September 2011 - 09:20 AM
Been a little while since I've got back to check this thread, once again the work looks superb! So many amazing little bits of detailing, love it!
#274 Tupers
Tupers
  • 4,142 posts
Posted 20 September 2011 - 07:18 PM
Thanks Adam, I think in the end the little details will really make it but for now they're killing me. >_<
After sitting and looking at the engine bay I decided I wanted to smooth off the seam between the crossmember and the bulk head.
After using the Oxy torch and multiple wire brushed I managed to get the seam sealer out of the joint and then welded it up and made a start on grinding it back down smooth.
We've also been talking a lot about different cooling options and I've decided/been coerced into using a front mounted alloy MGF rad. With that in mind I drilled out the welds holding the old rad shroud on and will be filling in the old slats.
I also put my shrinker stretcher into action making the right angled sections that will join my rear quarters to my inner arches when the gets around to tubbing the rear.
I started out with two 1M folded lengths of steel and ran them back and forth through the stretcher to curve them to match the radius of a wheel arch tub.
This is what it looked like after running through the stretcher twice.
And after a bit more tweaking I got it to match almost perfectly.
Edited by Tupers, 20 September 2011 - 07:30 PM.
#275 jagman.2003
jagman.2003
  • 1,307 posts
  • Local Club: Owner of my own club of Minis
Posted 21 September 2011 - 12:00 PM
Some great ideas & attention to detail here, well done, keep up the good work.
#276 Tupers
Tupers
  • 4,142 posts
Posted 22 September 2011 - 09:48 PM
I got the other arch curve knocked out this morning so now I'm all really to start tubbing the arches.
With all this talk of front mounted rads I though I'd better make a mock up the same size as the alloy MGF unit to check the size. I think I'm going to go with something slightly shorter and narrower to leave some room for an oil cooler and of course air to the carb.
After lunch I turned my attention to making a new N/S flitch to get rid of the original slats.
I started out by going over the different angle changes in the O/S flitch with a marker pen and then copying those lines onto several sheets of A4.
I then taped the sheets together, flipped them over and traced over the lines to create a mirror image of the O/S flitch.
Before committing to big sheet of steel I did a small test piece to see if my proposed method of forming would work. The basic idea is to chase over the markings with a hammer and chisel to form lines in a similar way to a press break.
When I was happy that this method would work I set about creating the new flitch. All in it's got 13 angle changes and took me about 3 hours to beat out.
It still needs a little tweaking but with any luck it'll be all welded in by lunch tomorrow.
From the top the original flitch and my one look pretty close although it's a little hard to see it without paint.
Edited by Tupers, 22 September 2011 - 09:52 PM.
#277 bcjames
bcjames
  • 2,728 posts
Posted 22 September 2011 - 10:02 PM
Impressive as ever! Nice work on that inner wing. Good to see the Eastwoods being put to use too.
#278 grahama
grahama
  • 2,442 posts
Posted 23 September 2011 - 06:58 AM
Blimey, you are turning into a legend !! You must have the patience of a Man City fan before the cash !! Really impressive work.
Graham
#279 DaveJH
DaveJH
  • 393 posts
Posted 27 September 2011 - 08:13 AM
More great work, any more updates?
#280 Tupers
Tupers
  • 4,142 posts
Posted 27 September 2011 - 07:12 PM
Thanks Dave. I wont have any more pics for you guys until Thursday night, bit busy on my other job at the moment. >_<
#281 benjy_18
benjy_18
  • 1,038 posts
  • Local Club: LSMOC
Posted 27 September 2011 - 07:22 PM
pretty shoddy if im honest, look at the size of that gap at the top!
PFT as if i can call that bad, looks awesome! worthwhile 3 hours i think.
keep it up chris
#282 Tupers
Tupers
  • 4,142 posts
Posted 27 September 2011 - 07:47 PM
I really should try harder shouldn't I Ben. :lol:
#283 madboy
madboy
  • 272 posts
Posted 27 September 2011 - 09:14 PM
just read this from start to finish , excellent ;D
#284 Tupers
Tupers
  • 4,142 posts
Posted 29 September 2011 - 10:30 PM
Thanks madboy it's been a bit of a journey. :lol:
The flitch on the O/S has a brace that comes off the front panel to reinforce it but due to the placement of the rad on the N/S it's not there. :(
So I made one. :mrcool:
I also finished trimming the new N/S flitch and welded it in.
#285 rich2
rich2
  • 351 posts
Posted 30 September 2011 - 11:54 AM
I cannot believe you beat that complicated shape out of a sheet of metal. Kudos! My hat off to you sir!
