Resistance On The Fuel Sender?
2 replies to this topic
#1 Joethemojomower
Joethemojomower
  • 100 posts
  • Local Club: no
Posted 05 January 2010 - 06:00 PM
what should the resistance read on the fuel sender??
I think this maybe why my fuel gauge isnt working. if not nany thoughts??
Its a 1982 mini HL
cheers Fellas/Fella'es :D
#2 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 05 January 2010 - 06:16 PM
The following values are nominal extremes.
Full = 10 Ohms
Empty = 270 Ohms.
The actual range will vary from sending unit to sending unit. A more reasonable expectation would be a range from 240 Ohms = empty to 33 Ohms = full... which is an industry standard.
If you suspect your sending unit is bad, the easy test is to jumper the two sending unit terminals together with a short piece of wire or a paperclip. With the terminals jumpered, turn the ignition switch to the run position. If the gauge goes to full, the gauge is OK. Anything less than full indicates a problem elsewhere (gauge, voltage stabilizer, corroded earth connection, etc.)
#3 Joethemojomower
Joethemojomower
  • 100 posts
  • Local Club: no
Posted 05 January 2010 - 06:25 PM
thats brilliant, thank you :D
i will check that as soon as i get home, thats a great help, cheers :gimme:
