Front Subrame Won`t Fit My Shell
Posted 04 January 2010 - 07:24 PM
The Z Cars frame is out by a full half inch on the turret centres, there are no signs of any damage what so ever. I contacted the previous owner to enquire but he told me that he never actually fitted it to his car.
I find it hard to believe that Z Cars would make it that far out, but I`m not sure which part needs altering. I dont think trying to mod the bulkhead would be a very good idea. but to alter the frame would mean cutting out the rear rails, shortening, then squeezing the turrets together to the correct dimension and then re-welding in the rear rails. So which ever way I go it`s going to mean a fair bit of work.
Has anybody else experienced a similar problem
Your comments would be most welcome.
Posted 04 January 2010 - 07:49 PM
My tubular front subframe turrets seemed to be out by about 10mm. Thing is I just got one into position and applied a bit of pressure by hand to the other turret and the subframe must have flexed just a little bit as it all popped into place.
Edited by Pete649, 04 January 2010 - 07:51 PM.
Posted 04 January 2010 - 07:55 PM
thanks
john
Posted 04 January 2010 - 08:57 PM
My first frame was like this i just use a strap to pull both side in till the holes alined.
thanks
john
Same here.....
Posted 04 January 2010 - 09:32 PM
Posted 04 January 2010 - 10:08 PM
DSCF1101.JPG 3.21MB 57 downloads
Posted 04 January 2010 - 10:46 PM
I sent it back to Z cars and asked for another one.
Apparently the shells come in 2 different shapes.
Posted 05 January 2010 - 12:33 AM
Mine was this way too
Posted 05 January 2010 - 09:31 AM
Posted 06 January 2010 - 11:48 PM
If you line up the holes so it does fit, the rear tabs dont fit where the firewall and the floor come together? They sit approx 1-2 inches to far forward? If this is the case this is a known problem and on the builder DVD. You need to use a solid spacer that goes against the firewall. If this isnt what your talking about I would add some images to your post so we can try and help.
Ring Chris or Richard at Zcars and they will take of you, great guys to work with.
Posted 08 January 2010 - 04:26 PM
I wasn't happy with the solid spacer option, i bought the frame primarily to save weight and had it built in thinner CDS tubing so wasn't happy putting spacers in that weigh as much as a house brick!!
Looking at that yellow frame for the A series, it appears the back legs are now adjustable?
Edited by R1minimagic, 08 January 2010 - 04:27 PM.
Posted 08 January 2010 - 04:40 PM
It will work just really have to get stuck in and maybe need 2 or three people
Mark
Posted 08 January 2010 - 04:48 PM
Fair enough if the uprights dont quite line up, they are easy to adjust with ratchet straps or otherwise (i had to file mine down a bit on the 'tower' mounts)
Chris was aware at the time that there seemed to be 2 types of bodyshell, those where the frame fitted the floor perfectly and others where they all appeared to have a gap of ~15-20mm. At first Chris thought the ones that didn't fit were accident damaged cars but that wasn't true. I know personally that he did a lot of head scratching over it and now seeing that yellow frame on the other post by Semag it looks like the legs are adjustable to compensate.
Posted 09 January 2010 - 09:45 PM
if you think about it the frames have a lower set of rails then a bar from left to right in a big curve around the front so it ends up a pretty wierd shaped thing
we have tried various ways of welding in sequances etc to no avail
if you measure them before powder coating they are different when they come back as they have been baked in an oven and move again due to the heat stress relieving he structure
the two top mounting holes are easily either porta powered out or ratchet strapped together to get them aligned
once they are in place they wont move and are back to where they need to be as they were when originally built in the jig
i used to have a mate who worked in a huge engineering business and they regularily straightened two foot deep sectional beams for trusses for buildings and similar by running weld along one side of the beam then grinding it flat afterwards it was amazing to watch him do it as over the years he got an eye for where the weld needed applying
chris
Posted 10 January 2010 - 03:27 PM
