Steering Seems Alittle Lighter Than Normal?
10 replies to this topic
#1 luiji89
luiji89
  • 1,039 posts
Posted 02 January 2010 - 07:19 PM
hey all, recently i had a crash but my mini is still drivable, i have had everything checked over nothing other than bodywork is damaged so thats all fine, i dont know weather it is in my head but the steering seems pretty light!. there is alittle but of play in the steerign wheel both ways before it actually feels to do anything... is this normal?
cheers toby
#2 xBR4DLEY
xBR4DLEY
    >>mine's still gay<<
  • 1,618 posts
Posted 02 January 2010 - 07:21 PM
Checked your track rod ends mate?
When mine was disconnected it was the easiest thing to steer
Or maybe someone fitted a power steering pump when you weren't looking :D
#3 luiji89
luiji89
  • 1,039 posts
Posted 02 January 2010 - 07:23 PM
everything has been checked, maybe the steering rack bolts or something... or is it just in my head?!
#4 luiji89
luiji89
  • 1,039 posts
Posted 02 January 2010 - 07:51 PM
anyone?
#5 fishey798
fishey798
  • 562 posts
  • Local Club: Mini Rebels
Posted 02 January 2010 - 07:52 PM
Get the tracking checked, if this is out it can cause the steering to be light. Quite possible due to being in an accident.
#6 AGoaty
AGoaty
  • 225 posts
  • Local Club: 16v Mini forum
Posted 02 January 2010 - 08:26 PM
Sure it's not just icy??? :D
#7 1.3Cooper
1.3Cooper
  • 39 posts
Posted 02 January 2010 - 10:46 PM
anyone?
I have had this on other cars - def worth checking - sorry meant to quote the post about checking your tracking but quoted the wrong one!!!!
Edited by 1.3Cooper, 02 January 2010 - 10:48 PM.
#8 luiji89
luiji89
  • 1,039 posts
Posted 02 January 2010 - 10:56 PM
hey all, its not as much light steering i dont think i can turn the steering wheel quite abit before it actually tirns the car alot etc its almost like play on both sides... any ways to make this tighter/less?
#9 MiniAlex
MiniAlex
  • 734 posts
  • Local Club: Mini's N Oatcakes
Posted 03 January 2010 - 12:12 AM
I hit a pothole in my Mini and it isn't driving right... but my Dad said to me that it's in my head... But it feels so much lighter :S
It's off to the garage soon for two new tyres and I am going to have the tracking tested. Hope there is nothing wrong with it :D
#10 62S
62S
  • 1,243 posts
  • Local Club: You must be joking!
Posted 03 January 2010 - 12:38 PM
Apart from the tracking would suggest you check that the rack U bolts are still bolted securely to the bodyshell. Would be worth checking the all front subframe mountings as well if its a post 1976 car.
#11 maddogmcg
maddogmcg
  • 233 posts
Posted 03 January 2010 - 02:33 PM
also check the pinch bolt at the bottom end of the steering column ,the splines on the steering rack can strip off if the bolt has come loose ,so make sure you check them too before just tightening up the bolt .
cautionary tale /........ a mate of mine wrote his woody estate off because the splines on his rack were stripped ,cant be too careful !!!
