V Power
Posted 31 December 2009 - 06:24 PM
Posted 31 December 2009 - 06:47 PM
so slight improvement in how it runs and small amount of power
to be honest unless its been mapped on 97ron octane not worth it
Posted 31 December 2009 - 07:35 PM
well the car has a lambda sensor and a knock sensor so will advance the ignition timing slightly
mini's do not have 'Knock sensors', the engine design is too old to incorporate it.
the only thing Vpower will do in an injection mini is clean the engine after repetitive use, therefore giving slightly improved performance.
Although in a carbed mini it can give performace gains through tuning but once setup on vpower, a carbed engine will require Vpower every tank after that.
SFM, please stop giving Misinformation!
Posted 31 December 2009 - 07:41 PM
Posted 31 December 2009 - 08:02 PM
i said unless mapped / set up properly won see gains ie i was right
get of ur high horse arse
Posted 31 December 2009 - 08:10 PM
mis information due to me not knowing the spi doesnt have a knock sensor
Wow....
I didnt realise you could put arse in a post and the forum wouldnt substitute it for *bottom* or something....
Thats.... AMAZING!
Posted 31 December 2009 - 08:21 PM
Ran Boris on it for a while and there did seem an improvement
In Saying that though it was before i got his new exhaust,now im back on 95Ron with a Maniflow DTM and its just as good if not better than when using Ultimate or Vpower with the old exhaust on
As for cleaning the valves etc i just throw a bottle of STP injector clear in the tank every 2000 miles or so when i do services
work out cheaper
Huggz
Jodie
Posted 31 December 2009 - 09:30 PM
Paul.
Posted 31 December 2009 - 09:58 PM
But you did say a Mini has a knock Sensor, which it doesn't. Not that it's the end of the world though.
Just use good quality fuel in your Mini and it'll run happily.
I've heard that older non-unleaded ready Minis seem to run better on the high octane fuel (with a lead additive or a modified cylinder head with hardened inserts). Where as post 1989 unleaded models are happy with 95ron and don't appear to run any different on the high octane stuff.
Edited by taffy1967, 31 December 2009 - 09:59 PM.
Posted 31 December 2009 - 10:19 PM
I have a cooper 1.3 spi and was just wondering if using V Power or equivalent makes any difference to the performance.
If you mean that you'll notice on the road? No
Are you getting the full bang on octane rating? You'll never know how long its been sitting there? All the super stuff dont stay super all the time.
Posted 31 December 2009 - 10:31 PM
Out of interest, how high could you safley go with a A+ engine?
Posted 31 December 2009 - 10:33 PM
Fith-gear did a test on 3 cars ranging from a 1.2 clio a Mk5 golf gti and a subaru impreza and they did make a
difference in performace but only to the golf and subaru both forced induction cars.
I arnt saying im 100% right
Posted 31 December 2009 - 11:06 PM
Thats how I see it anyway.
Edited by Pauly, 31 December 2009 - 11:07 PM.
Posted 31 December 2009 - 11:50 PM
Octane has nothing to do with power and 'bang' its how controlled the combustion is. Higher octane fuels will ignite on, or closer to the actual point of ignition, whereas lower octane fuels will detonate/diesel as the piston rises on the compression stroke and heats the mixture.
That is not quite right.
Pre ignition is what happens if the charge ignites for what ever reason, before the spark has occured. Knock is generated by normal combustion. The flame initiated by the spark causes a rise in cylinder pressure and temperature, A second flame can start at the other end of the combustion chamber by spontanius combustion. This causes a suden rise of cylinder pressure and this is knock, or pinking. Knock normaly occurs at or around 14 degrees after top dead center. Detonation is much the same, but much more severe.
Knock is brought on by several factors, charge temps, engine temps, fuel octane, compression ratio, cam profile and of course ignition advance. All these play together and if you get it wrong, the party wont last long.
Also the charge does not explode or go bang. It is a burn. The difference between the two is simple. An an explosion is an uncontrolled decomposition of the charge. A burn is a controlled decomposition of the charge. The 'bang' in the exhaust is as a result of the sudden release of combustion gasses leaving the cylinder at high pressure, in a similar vien to a ballon going bang when it is popped.
There is more to Vpower than its octane rating
Happy new year by the way
Edited by Sprocket, 31 December 2009 - 11:52 PM.
Posted 01 January 2010 - 12:04 AM
There is more to Vpower than its octane rating![]()
Happy new year by the way![]()
Like what?
Im interested to know if its worth useing either Vpower or Ulitimate over the standerd fuels, and why.
What fuel do you run by the way?
