1098 Pistons?
Posted 29 December 2009 - 09:56 PM
Posted 29 December 2009 - 10:04 PM
Posted 29 December 2009 - 10:08 PM
Posted 29 December 2009 - 10:40 PM
Edited by bmcecosse, 29 December 2009 - 10:41 PM.
Posted 30 December 2009 - 08:41 AM
Can anyone help me i.d. these pistons please? I bought them recently as they are supposed to be 1098 flat tops. I'm not convinced however as they seem to measure up much the same as 998 flat tops. My understanding is that 1098 pistons are shorter ie the con rods are the same as 998, it's the crank that alters the stroke, block height being the same therefore 1098 pistons need to be shorter?
Like others I can't open the picture, but I can confirm that the 1098 piston is shorter,
To my knowledge Flat top pistons 1098 pistons in oversizes are only available from Omega - via swiftune
There is a listing on ebay that lumps all the small bore sizes: ie; 997 998 1098 together but having contacted them last year they need to know that you want 1098 pistons as they stated they have different heights, but you need to tell them when you order.
Where did you get them from?
Posted 30 December 2009 - 08:45 AM
the /50 is the oversize in 100th's of a mm, so in real money are +20 998 pistons..
Edited by Guess-Works.com, 30 December 2009 - 08:48 AM.
Posted 30 December 2009 - 08:47 AM
Posted 30 December 2009 - 08:49 AM
Posted 30 December 2009 - 08:51 AM
Posted 30 December 2009 - 08:53 AM
Posted 30 December 2009 - 08:57 AM
If your dealing with a company they may sort it out.
If its a private seller you would have to prove the listing was incorrect.
Which was it?
Posted 30 December 2009 - 11:08 PM
Posted 06 January 2010 - 09:58 PM
Posted 06 January 2010 - 10:04 PM
Posted 06 January 2010 - 10:46 PM
this is the top of my piston
what rings do i need??
sorry for hijacking
