Diy Supercharger Running
#16
Posted 09 January 2010 - 09:05 PM
for £10 its worth the risk.
will let you know how it goes
joe
#17
Posted 15 January 2010 - 06:54 PM
#18
Posted 25 February 2010 - 08:14 PM
Just an update on carb heater. All works great have no problems of carb icing up now.
RS stock No 299-5843 PCT & priced just under a tener
#19
Posted 17 March 2010 - 03:50 PM
#20
Posted 13 May 2010 - 10:49 PM
#21
Posted 15 May 2010 - 08:44 PM
i have considered this before myself, im sure im up to the job of making the manifolds and brackets, its more about the down time on my mini, i cant live without it for long!
#22
Posted 18 May 2010 - 07:39 PM
The only problem i'm having is on tick over, when the ambient air temp goes up so dose tickover. Just today i have unscrewed tickover screw to drop the reves down because its getting warmer.
I might make up a new shorter one but at the mo i'm just enjoying driving it
#23
Posted 19 May 2010 - 11:40 AM
I made up the inlet with the view of its what other makers are doin & i'm sure they have played about with different length inlet tracks. Maybe its just down to getting all mini's with servos to fit. Or getting fuel & air to atomise properly.
I'm sure no one could blame you for that, it looks awesome. Did the heater make a difference? Any ideas on the power you're making?
#24
Posted 21 May 2010 - 07:48 PM
I did mean to put it on the rollers but havent as yet so have no idea on power
On this site i found what needles people are using & have set it up myself, also tried 3 different weighted carb springs on each needle & found what works. Still need to check on the rollers to see how its running flat out in top gear to be sure. It sits at 90mph ok & still wants to go!
coming up for a 1000 miles now & no troubles
fingers x
#25
Posted 03 August 2010 - 09:37 PM
not fitted and not sure if I'll even need it, but it should work.
I intend to put a switch in the circuit so I can choose to turn it on or off.
Its the RS PCT heater recommended on this topic.
I wasn't sure of the optimum position. In the end I decided to mount it on the centre pillar to heat the air rather than mounting it flat on the back panel to heat the carburettor. I would be grateful for people's views on this...
#26
Posted 04 August 2010 - 07:44 PM
Works perfectly
joe
#27
Posted 04 August 2010 - 08:34 PM
#28
Posted 06 August 2010 - 06:33 PM
Just jpeg number up there now?
#29
Posted 07 June 2011 - 08:53 PM
#30
Posted 09 June 2011 - 08:19 PM
