Diy Supercharger Running
46 replies to this topic
#1 joe90
joe90
  • 124 posts
Posted 22 December 2009 - 08:14 PM
Finally it goes!! just one problem the ambiant temp today was 1.5 deg c & carb started to ice up.
would like to use an electric pre heater & i see that vmax do one is this made in house? have looked at various
k&n sites but no one lists them.
What do you think?
#2 adam_93rio
adam_93rio
  • 3,271 posts
Posted 22 December 2009 - 08:22 PM
looks awsome, ive wanted to supercharge my mini for a while now, im only 19 tho so the inruance would kill me
how much power did you have before you put it on?
the only problem with them is the carb iceing up, the original design of the engine bay was to have the engine the other way round but the carb iced up so they changed it, now weve got damp electrics :lol:
i guess supercharging you just get the worst of both worlds haha.
get a video up of it running, and let us know how much power increase you get
#3 THE STIG
THE STIG
    Da stig says, GO GO GO
  • 2,506 posts
Posted 22 December 2009 - 09:13 PM
you say the carb was icing up do you mean the inlet from the carb to the supercharger
if was that mine used to ice up even in the summer , but never caused a problem
you used to be able to buy a carb spacer plate with a heater wire in it for cold climites but you dont make them any more and are hard to find
#4 71Pickup
71Pickup
  • 94 posts
Posted 23 December 2009 - 01:06 PM
VMAX sell an anti icing kit. not sure if its any good though.
N :D
#5 Ethel
  • 25,919 posts
Posted 23 December 2009 - 01:17 PM
Quite a few Rovers had abutment (induction) heaters, I think the SPI does and K Series.
#6 clambert81
clambert81
  • 268 posts
  • Local Club: Crewes Missiles
Posted 23 December 2009 - 01:27 PM
That looks very tasty. Cracking job. Let us know what it's like to drive.
#7 THE STIG
THE STIG
  • 2,506 posts
Posted 23 December 2009 - 11:25 PM
i had thought that if it ever caused a problem i thought about forming some 15mm cooper pipe around the inlet tract and connect it into the heater pipe heater
easy to do and would warm up the whole inlet tract
#8 steble
steble
  • 750 posts
  • Local Club: chichester mini club
Posted 24 December 2009 - 12:15 AM
vmax scart do a heated air filter, its a normal k and n cone filter but vmax put a electric heater element in it to try and stop carb ice.
but as i discovered if its really cold this dont work it looked like the antartic under my bonnet the other day
#9 joe90
joe90
  • 124 posts
Posted 24 December 2009 - 08:45 PM
thanks for the replys
The inlet track was starting to ice up. then tick over started to drop so i took off the k&n filter & the carb itself was iceing up all round the butterfly.
i did think about using copper pipe round as you say.
I have had another idea of using a glow plug inside the filter, maybe with a variable resister & switch. just need to find one small enough to go in the filter.
i might not have the same trouble when the weather warms up a bit
freshly built van & engine is not going out on the roads just yet, can't wait tho
#10 tcw_lk
tcw_lk
  • 33 posts
  • Local Club: Mighty Mini Club of Sri Lanka
Posted 28 December 2009 - 12:51 PM
nice work ;)
#11 shellspeed
shellspeed
  • 233 posts
Posted 05 January 2010 - 11:13 AM
http://uk.rs-online....ting#breadCrumb
From RS Components - you will need 12-24v element but not sure of the watts involved - cheap enough though!
#12 paul6266
paul6266
  • 482 posts
  • Local Club: Retro Classics
Posted 05 January 2010 - 11:20 AM
this looks very tasty, i was thinking about making my own set up but from what i have heard the inlet is a bit of a arse to fabricate
#13 THE STIG
THE STIG
  • 2,506 posts
Posted 05 January 2010 - 11:28 AM
they look like would work inside the filter
the 20w gives of 40C the 80w gives of 100c surface temp
#14 richardsoniscool
richardsoniscool
  • 629 posts
  • Local Club: Bury Mini Club
Posted 07 January 2010 - 01:03 PM
did you make the inlet yourself??
#15 joe90
joe90
  • 124 posts
Posted 07 January 2010 - 08:52 PM
That looks very handy!!!
I have an rs store just down the rd from me will have to check that out. Thanks for that.
Yes i made the manifolds myself & has been said here a complete arse to make right.
Unless you have a lot of free time & patience i would advice to buy one.
VERY REWARDING WHEN IT FIRED UP SECOND TIME!!!! :xxx:
