Megajolt Kit
25 replies to this topic
#1 GreaseMonkey
GreaseMonkey
    Has Ratchet, Will Make Noises
  • 3,663 posts
Posted 22 December 2009 - 12:18 PM
Please don't trust this fraud, see the link in my sig.
Edited by GreaseMonkey, 14 October 2010 - 03:41 PM.
#2 Steve D
Steve D
  • 128 posts
Posted 22 December 2009 - 12:25 PM
Thanks for the kind words, and glad you happy with the products.
Steve
#3 richardsoniscool
richardsoniscool
  • 629 posts
  • Local Club: Bury Mini Club
Posted 22 December 2009 - 01:02 PM
Whats the price of the kit - minus the pulley / mount? i really want megajolt nothing but goods things said about it.
cheers.
#4 Steve D
Steve D
  • 128 posts
Posted 22 December 2009 - 01:09 PM
cheers.
PM Sent
#5 t@z
t@z
  • 1,712 posts
  • Local Club: www.turbominis.co.uk
Posted 22 December 2009 - 01:52 PM
be really nice if there was a price actually on the website for the kit as it seems pretty interesting but i'm sure there are people like me who just cant be bothered to ask. having done one already its not hard but it saves time etc.
#6 backstreetclassics
backstreetclassics
    Previously known as minidan07
  • 1,898 posts
  • Local Club: essex mini club
Posted 22 December 2009 - 04:24 PM
how much does the kit cost ????
#7 luvlygal
luvlygal
  • 1,297 posts
Posted 22 December 2009 - 04:32 PM
What they said :lol:
#8 Steve D
Steve D
  • 128 posts
Posted 22 December 2009 - 04:59 PM
To answer the question of how huch the kit costs.
1/ The Megajolt Lite Jr. (MJLJr (MAP) £140.00
Megajolt V4 mounting brackets
Serial Tuning Cable
CD including: Megajolt programme, Installation instructions
7no mini maps.
1m of Silcon vacuum hose
2/ CNC machined full replacement bottom pulley with trigger £90.00
and sensor bracket
3/ Fully made installation wiring loom including sheiled wire £40.00
4/ Edis, Coil pack, and sensor £40.00
#9 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 22 December 2009 - 05:22 PM
How do the features of this compare to a comparable package, say the Specialist Components Storm ignition system ?
#10 Steve D
Steve D
  • 128 posts
Posted 22 December 2009 - 05:43 PM
The SC Storm ignition system is a very good ecu unit. The storm kit includes the following items for £345 + Vat so the price is £396.75.
and includes the following
The Storm package:
• SC Storm ignition ECU
• Complete wiring harness
• USB A-B Lead and software CD
• Crankshaft position sensor
So you still need a coil pack, and trigger wheel a MAP sensor which is £55 + vat or a DCOE/DHLA Carburettor Throttle Position Sensor
Price : £59.00 + vat.
So to get a storm kit up and running it will set you back around £479 plus vat £550
As the SC storm package is very good. The megajolt package is cheaper and alot of people are able to make their own kits.
#11 THE STIG
THE STIG
    Da stig says, GO GO GO
  • 2,506 posts
Posted 22 December 2009 - 05:49 PM
so the answer to how much does the kit cost is £310
#12 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 22 December 2009 - 05:50 PM
The SC "Mini Kit" includes the trigger wheel, but was more interested in the features and post sale support comparison...
Basically as I'm interested, need a mappable ignition system for my planned engine build capable of 3D map upto 10k rpm.
#13 Steve D
Steve D
  • 128 posts
Posted 22 December 2009 - 05:52 PM
Yes it is £310 Including postage the whole unit weighs around 4kg, but I am up for a deal. You just need to ask.
#14 Steve D
Steve D
  • 128 posts
Posted 22 December 2009 - 05:57 PM
The main features are.
The Megajolt Lite Jr. is designed to work with the commonly available Ford EDIS 4,6 or 8 cylinder ignition module. Combined with inexpensive and easy to obtain OEM coil pack(s), trigger wheel and crank sensor, you can realize your engine's potential at a fraction of the cost of other systems.
The V4 controller is now more compact and rugged, and adds an new auxiliary input for reading a temperature sensor or other signal. Oh, and did we mention a shiny new case? DIY can be beautiful, too!
Major Features:
3D ignition mapping: 10x10 ignition advance grid with full linear interpolation smoothing between cells
Dual, on-the-fly switchable ignition configuration
Analog auxiliary input to further adjust ignition advance
Four user-defined output switches, which trigger on RPM, Load or Auxiliary input, plus shift light output
Modern, easy to use, and customizable Windows-based Configuration/Tuning software Screenshots
1000's of satisfied users worldwide-
Hope this helps
#15 Steve D
Steve D
  • 128 posts
Posted 22 December 2009 - 06:36 PM
Here is a quick video of a megajolt system running on a mini.
<object width="425" height="344"><param name="movie" value="http://www.youtube.c...></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.c...hl=en_GB&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>
