Minispares Cross Pin Diff
Posted 20 December 2009 - 01:48 PM
Managed to build my cross pin diff up today but it seems to lock up when you torque the crown wheel down?
Paul.
Posted 20 December 2009 - 04:39 PM
Try some good used ones
Posted 20 December 2009 - 06:38 PM
Paul.
Posted 21 December 2009 - 07:34 AM
Posted 21 December 2009 - 08:33 AM
Posted 12 February 2011 - 08:53 PM
Got the same problem today. Purchased an Minispares-Crosspin-Diff and it locks if i torque down the crownwheel. Tryed to use the old fibre washers, but it still locks...
tryed the second Diff from an Friend, the same problem... (both purchased Dec 2010).
Compared to an old Minispares Diff mine looks a little bit different (Holes for crown wheel are drilled through and the planet gears looks different)
Parts are also not changeable.
Is it an new manufacturer?
Posted 13 February 2011 - 08:39 AM
minispares x-pin should look very similar to this...
http://www.guess-wor...m/Tech/Xpin.htm
Posted 13 February 2011 - 12:24 PM
no Problems to this Stage....
as i tryed to torque up...locking. On both differentials
difference of teeth between original planet gears and the new Minispares planet gears...
from this diff are the output shafts
Edited by minischubi, 13 February 2011 - 12:24 PM.
Posted 13 February 2011 - 12:31 PM
If it still doesn't turn then, try dru building it with no fibre washer's at all and see it it turns then.
If so it will be a case of sanding the fibre washers down enough so that the diff can turn.
Posted 13 February 2011 - 05:54 PM
- changed planetwheels crosswise: no effect, still locking
- build up without one fibre washer, non locking, but turns very roughly, seems like the tooths are not really matching
- build up with some old planet wheels (Diff-pins have the same diameter): it works, and runs smooth
the difference between the old planet wheels and the new one from the Cross-Pin-Diff. The teeths are very different i think.... could this be the problem?
Measured the distance between Pin and surface for the Crown wheel, both Cross pin diffs are 0,3mm (12 thou) shorter than the original diffcase.
@southy: used new and also old washers, no difference at all. Also there are the thinnest possible washers in the Kit. Didn't like the idea of sanding down the washer. I think its possible that there are then parts of abrasive grains in the washer...not so good i think. also it still runs very roughly...
Edited by minischubi, 13 February 2011 - 05:55 PM.
Posted 13 February 2011 - 06:53 PM
Posted 13 February 2011 - 07:07 PM
If i remember rightly i had this same problem, it turned out in the end there was a thin remanant of the old fibre washer that was perfectly round and looked like metal but it wasnt. Removed this and all was good.
on the output shaft? I'll check this..
