N/s Rear Quarter Panel Repair
11 replies to this topic
#1 Kerrin
Kerrin
  • 1,056 posts
  • Local Club: Manx Mini Register
Posted 20 December 2009 - 12:58 AM
I am in the final stretch of the bodywork of my project mini.
The N/S 1/4 panel is rusty down by the sill join. I have got a full step and 1/4 anel repair but thinking of using sections of it just to patch the rust.
How does the rear side panel come off the B pillar, I am only removing and repairing the bottom 6" can i do a horizontal cut and just drill the spot welds off the pillar joint.
Also how much metal is at the bottom of the B pillar, do i have to go really careful with cutting the outer skin.
Any photo's would be great or I can try and do photo's of the problem if I have confused everybody, I read shiftys project but his looked really rotten and i dont want to chop that much out.
#2 jameswhiles
jameswhiles
  • 309 posts
  • Local Club: A5 Minis
Posted 20 December 2009 - 09:55 AM
I think you would be better off cutting it all out rather than just patching.
I suppose if its just rusted along the sill joint then you can get away with only cutting 1 or 2 inch upwards and then trimming down the new panel. This way it will be stronger than patches, and probably easier than patching. You will also end up with a better finish by doing the lot, than if you tried to patch it
#3 Kerrin
Kerrin
  • 1,056 posts
Posted 20 December 2009 - 08:21 PM
Yes I see what you mean. I just would like to keep the seam/joint where the rear 1/4 fits to the pillar, the repair panel is just flat and would bug me. :cry:
I was going to use the rear 1/4 and leave a short section of the step under the B pillar and use the rest of the repair panel for the rust repair of the step and A pillar.
I will cut it all out and then look how best to fix it.
#4 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,135 posts
  • Name: Sean
Posted 20 December 2009 - 08:26 PM
Yup, thats fine.
The full length steps with no stepped join bug me as well. Wherever possible I try and retain this joint. As you say the best way is to cut the repair panel in 2 and use it either side of the joint.
I've done this loads of times.
#5 Kerrin
Kerrin
  • 1,056 posts
Posted 20 December 2009 - 08:29 PM
Ah great, thanks shifty, does the rear 1/4 seam that lips round the pillar come off fairly easy or are there any tricks.
#6 Shifty
Shifty
  • 13,135 posts
  • Name: Sean
Posted 20 December 2009 - 08:30 PM
Like this
#7 Surfbluegarage
Surfbluegarage
    AKA mini_mad_daps
  • 1,547 posts
Posted 20 December 2009 - 08:31 PM
nice photo op for 1275 sprites mini there..lol smile your famous :cry:
#8 Shifty
Shifty
  • 13,135 posts
  • Name: Sean
Posted 20 December 2009 - 08:35 PM
If you hadn't been going to Mc'ds with the Chavs today, you'd have seen it in person!!!
(drift-boy!!)
#9 Kerrin
Kerrin
  • 1,056 posts
Posted 20 December 2009 - 08:40 PM
Great. Ta.
Newly inspired, I will make a start tommorrow night.
#10 Surfbluegarage
Surfbluegarage
    AKA mini_mad_daps
  • 1,547 posts
Posted 20 December 2009 - 08:45 PM
mc d's with what chavs? me a chav! how dare the shifymus-prime! ill have you know the drifting was in a safe and secure venue... in a field... lol :cry:
and not to drift from topic thats how id do it to.. hate seeing those hadrian one piece things on minis... lol
#11 Kerrin
Kerrin
  • 1,056 posts
Posted 23 December 2009 - 08:48 PM
So far so good.
Just a bit of cleaning up and the repair can go in, the pencil line at the top is the guide for the joggler (new toy).
#12 kez301
kez301
    Starting My Mini Up
  • 4 posts
Posted 16 February 2016 - 03:27 PM
I had one of those repair panels fitted and regret , as soon as funding allows i shall be having a new quarter panel fitted.
