Asda 20w50 Oil?
#16
Posted 20 December 2009 - 12:19 AM
#17
Posted 20 December 2009 - 12:20 AM
#18
Posted 20 December 2009 - 12:24 AM
#19
Posted 20 December 2009 - 09:10 AM
Its the only stuff I use.. I have no problems with it
How do you know ? Unless your taking samples and having them analysed for wear metals etc then it's impossible to tell whether it's causing problems or not.
As said further up in this thread it's not worth scrimping on engine oil as you get exactly what you pay for. If it's cheap to buy then it's cheap oil that wont be very shear stable which means it will thin out very quickly and although may start life as a 20W50 may soon become a 40 grade !!
#20
Posted 20 December 2009 - 09:13 AM
Also, as Greyedout said, you are not going to know if there is any engine wear taking place unless you do a used oil analysis and you would also need a reference oil to compare against.
Edited by R1minimagic, 20 December 2009 - 09:18 AM.
#21
Posted 20 December 2009 - 09:46 AM
But equally you don't know whether the more pricy oils are any good either, just because they have fancy names and adverts (which is all reflected in the price) dosen't automatically mean they are that much better.
The A-series in a Mini is a little unusal as it shares the oil with the gearbox, so oil type will always be a compromise. IMO for a most road engines having their oil changed every 3 to 5 k then Asda oil will be fine. With no real evidence either way it'd be difficult to prove otherwise.
#22
Posted 20 December 2009 - 09:56 AM
I agree, just because the price is higher doesn't mean it is better!
I saw some engine oil in Lidl last year and was interested to read the specification, I was very surprised that it had a good specification and was only about £7-8, so it just goes to show. If the ASDA stuff has no spec on the container, don't use it!
Edited by R1minimagic, 20 December 2009 - 09:59 AM.
#23
Posted 20 December 2009 - 11:20 AM
The evidence is the ratings given to it under test that are written on the bottle. Asda oil doesn't have a rating, don't use it. Cheap oil is the same as cheap fuel, made from left overs and recylcled garbage with supplements added to get it to pass the specification. It doesn't last. It's precisely because it's used in the gearbox as well that you need something with quality to it and would want to know how well it performs. £5.00 worth of oil every 1000 miles, or £15 - £20.00 of oil every 3 - 5000 miles. Take filters and your time into account and this cheap oil isn't that cheap after all.
#24
Posted 20 December 2009 - 11:35 AM
#25
Posted 20 December 2009 - 11:47 AM
I know for a fact when I was in my teens it was the only oil I did use.
Just because they now have a bit of a classic status and are driven by enthusiasts doesn't mean in a past life they weren't driven by 17 yr olds with no money
#26
Posted 20 December 2009 - 11:54 AM
I think sometimes people forget most classic minis have been around a long time, you have no idea of the history of the car. Whose to say the previous owner didn't use the cheapest oil he could.
This may be true for lets say a mid 70s car with the original engine, but not say of the late MPis - mine had 16,000 miles, and judging by the previous owner's house, and mound of reciepts he didn't use cheapo oil. Also, the OP may have just bought his car with a freshly built engine, therefore absolutely no history of poor quality oil.
#27
Posted 20 December 2009 - 01:01 PM
#28
Posted 20 December 2009 - 01:35 PM
Quite agree you only get to find out poor oil has taken 20k miles off the life of your engine when it finally wears out.
I sent them an email, wonder if it'll get a reply?
#29
Posted 20 December 2009 - 01:42 PM
Mainly because my car leaks and I can't afford to keep topping it up with proper stuff.
I'll just have to wait and see what problems I get using it.
But for £5 you can't leave it there, it has to perform to a decent enough standard to be able to be sold, surely.
Ben
#30
Posted 20 December 2009 - 02:07 PM
by the way - Cheap fuel is not made from leftovers or recycled anything, it just doesn't have the same additive packages or approvals.
Edited by R1minimagic, 20 December 2009 - 02:09 PM.
