if it hasent got the slipper coller on it then get a socket that will only just fit and a half inch extention you dont mind smaking on the end and bash the sockert on then get a pry bar and ease it loose
if you not got pry bar use a ratchet and a bit of steal pipe/scaffolding
if its like the bmw mini ones with like the splines on the locking key you can oftern just smaks an extention in the splined hole dont be soft with your tools if there good quality it wont hurt them the locking nuts are mad of soft alloys and crapy metal they will break befor you tools will
also failing thes you will need a good drill along time and alot og drill bits and some one to spray easing oil on the bit while you try drilling it out. (you dont want to be doing)
if you live in an place with out much crimmanal activity then dont put lock nut on there waste off time people hardly ever steal wheel they just rob the shop that sells them
crimminals have goten lazy haha. good luck and have fun
Edited by me madjoe 90, 19 December 2009 - 06:11 PM.
