Air Horn Not Working
Posted 17 December 2009 - 04:34 PM
thanks
G
Posted 17 December 2009 - 07:10 PM
Posted 17 December 2009 - 07:17 PM
remove the pipe from the horns and add a little oil there too.
Edited by Sprocket, 17 December 2009 - 07:20 PM.
Posted 17 December 2009 - 07:27 PM
When it buzzes, is the compressor actually turning, or is it a "stuck" buzz. if there is no movement, perhaps remove the horn, and give the compressor a little tap to see if it frees off.
Just had a thought - you say the car has been stood - is the battery charged? - if you are only getting like 9V, perhaps this isnt enough power to overcome the force to sound the horn?
Ryan
Edited by L400RAS, 17 December 2009 - 07:28 PM.
Posted 17 December 2009 - 07:31 PM
worked great after that until i came to use it after a long perod 3-4 weeks and yes it was jammed again!!!
seems to be weakness to them
Posted 17 December 2009 - 07:38 PM
Posted 17 December 2009 - 07:40 PM
The stebel nautilus is an all in one airhorn, so unfortunately you cannot pour oil down the air pipe to the compressor.
Ryan
the battery wasnt connected while it was stood, but i think its charged the car starts fine and lights work fine not dim at all. i took the horn off the bracket and rested int on the engine while i hit the horn and it was buzzing all over the place.
have one of these on my festa van they are great but they are also prone to seizing through non use - completely stripped mine lubed it with milking machine oil (also kown as vacuum pump oil) but i presume most oils wil do.
i might need to strip it then. is it easy to take apart?
cheers guys
Posted 17 December 2009 - 08:14 PM
Posted 17 December 2009 - 08:23 PM
xx
i can get a picture of it if yu need.
Posted 17 December 2009 - 08:55 PM
Posted 19 December 2009 - 07:39 PM
wd40 - the miracle oil, cures all known ills...read our testimonals:its working now guys some wd40 and about 40 secs of running and its all good
Mr G: When my gearbox exploded whilst doing the le Mas 24 hour race, I sprayed a liberal amount of WD40 onto it and voila one working gearbox!
Mr B: I had a serious misfire in my rolls royce merlin engine in my spitfire whilst fighting gerry, a quick squirt onto my propellor and hey presto!
Mr T: When my leg was taken off by a crocodile in the Australian outback, one squirt of WD40 and hey, my leg is as good as new.
WD40 - THE MIRACLE OF THE MODERN AGE
Posted 19 December 2009 - 08:40 PM
http://www.gt85.co.uk/
Edited by Sprocket, 19 December 2009 - 08:41 PM.
