Vin Number Explain
Posted 17 December 2009 - 03:02 PM
Newbie here just bought a Classic mini. But I'm trying to figure out what engine and where it was build.
It's convertible and want to know if it's an original.
This is what the VIN plate says:
Austin Rover Group LTD
ABE 8224/3
SAX XL 2S1S21346249
Any help is greatly appreciated...
Thanks!!
Kurt
Posted 17 December 2009 - 03:25 PM
Note that the VIN plate for these cars is likely marked, “Austin Rover Group LTD”
It is possible that the dating in the factory microfiche is incorrect and the change date is October 1984, not 1985. Major changes were made by October 1984 (for instance, 8.4” brakes and 12” wheels became standard).
The general format for the VIN for these cars is:
SAX-X-K2S1N-XXX-A
VIN, First Three Positions (“SAX” in the above example):
This is the World Make Identifier. The factory microfiche indicates this was started on these cars in Feb 1981.
SAX = MG-Rover
VIN, Fourth Position (“X” in the above example):
This is simply dismissed by the factory as “non significant”!
VIN, Fifth Position (“K” in the above example):
= Engine type
C = 1098cc
K = 848cc
L = 998cc
VIN, Sixth (and Seventh) Position (“2S” in the above example):
= Body type
2S = 2-door saloon/sedan. Caution: bureaucratic bungles often interpret this as 25 (twenty-five)
2W = Estate (“2 Door Dual Purpose”)
G = P.O. Mail Van
U = Pick-up. Caution: U and V can be mistaken one for the other.
V = Panel van. Caution: U and V can be mistaken one for the other.
VIN, Eighth Position (“1” in the above example):
= Series of model
1 = Round nose, traditional Mini body style.
2 = Clubman, square nose style.
VIN, Ninth Position (“N” in the above example):
= Specification
N = HL, Special, HLE, or Mayfair
R = Mini 25
S = Mayfair (LHD – France only)
VIN, Number positions (“###” in the above example):
= The sequential build number:
Build numbers are not listed. It is suspected that they carry on with the numbers from the previous series of cars; i.e., numbers were not started from 101, again.
VIN, Last position (“A” in the above example):
= Assembly plant. Officially, “Internal Use Only”
If used at all, this would be “A” for English built cars.
A = Longbridge
Nov 1985 to Circa 1990?? – English Built
VIN
It is possible that the start date is really November 1984, not 1985 as stated in the factory microfiche.
SAX-X-L2S1N20-XXX-A
SAX = MG-Rover
VIN, Fifth Position (“L” in the above example):
= Engine type
L = 998cc
= Body type
= Series of body
= Class
N = HLE, Mayfair (RHD)
O = E, City E
S = Mayfair (LHD)
VIN, Tenth Position (“2” in the above example):
= Model year
2 = 1984 on (This conflicts with the microfiche indicating this position was used starting in November 1985.)
VIN, Eleventh Position (“0” in the above example):
= Steering
0 = RHD
1 = LHD
A = Longbridge
0 XN-----010001 On (1300cc cars only) – English Built
VIN
SAX-XN-N-A-Y-B-B-D-######
= World Make Identifier.
SAX = MG-Rover
VIN, Fourth and Fifth Positions (“XN” in the above example):
XN = Mini 1300
VIN, Sixth Position (“N” in the above example):
= Class
N = Sport, Cooper, Cabriolet
V = Kensington
W = HLS, Mayfair
Y = City, Sprite
VIN, Seventh Position (“A” in the above example):
= Body type
A = 2-door saloon/sedan.
B = Cabriolet
VIN, Eighth Position (“Y” in the above example):
= Engine
D = 1300 Carb
M = 1300 Carb
X = 1300 SPi (standard compression ratio, 9.4:1)
Y = 1300 SPi (high compression ratio, 10.1:1)
Z = 1300 MPi (high compression ratio, 10.1:1)
VIN, Ninth Position (“B” in the above example):
= RHD/LHD, Transmission type, Final Drive
B = RHD, Manual, 3.105
C = RHD, Manual, 3.21
E = RHD, Manual, 2.76
K = RHD, Automatic
M = LHD, Manual, 3.105
N = LHD, Manual, 3.21
R = LHD, Manual, 2.76
Y = LHD, Automatic
VIN, Tenth Position (“B” in the above example):
= Model Change
A = 1300 Special Edition
B = 1300
VIN, Eleventh Position (“D” in the above example):
= Assembly Plant
D = Longbridge
VIN, Number positions (“######” in the above example):
Starting with 010001
Posted 17 December 2009 - 03:28 PM
It's a 998 saloon, apparently French export model ( LHD )
Made before 1986...
Posted 17 December 2009 - 03:55 PM
Thanks for the info I also founf that page but it since I don;t think it was english build I was not sure how accurate it was. Also I was told the car is a 95 model?
Thanks again!
Kurt
Posted 17 December 2009 - 04:15 PM
Posted 25 September 2012 - 06:20 AM
I`m a Mini owner from year 2007 and now I have bought my second car (year 2000 old model) from Germany.
I have a problem with registering it over here in Estonia, because my car has a 12 digit VIN-code stamped under the bonnet but in the documents it is 17 digits. Do you`ve got any additional info regarding to the VIN codes? Why it is shorter? Local car registering company is waiting for additional info from me.
Is it true that late model have shorter VIN-code?
With Best Regards,
Janno
Edited by Janno, 25 September 2012 - 06:37 AM.
Posted 29 March 2013 - 11:09 AM
would like to know if my engine is the original one
any pics to show
cheers
jay
Posted 29 March 2013 - 11:18 AM
Posted 29 March 2013 - 11:27 AM
Posted 29 March 2013 - 11:33 AM
Posted 29 March 2013 - 11:35 AM
Posted 29 March 2013 - 11:42 AM
Posted 29 March 2013 - 11:45 AM
Posted 31 March 2023 - 11:38 AM
Hi... Just checking my VIN and the car is definitely a 1982 city E but the VIN style matches the 1985-1990 style coding
any ideas why?
Google (1)
