Socket Size For Spark Plug?
Posted 15 December 2009 - 08:43 PM
Need to retrieve my broken down mini. Gathering up some tools from the house before i go back out and im wondering what size socket i need for the spark plugs?
1991 City e
Posted 15 December 2009 - 08:47 PM
Posted 15 December 2009 - 08:49 PM
http://www.ngk.com/m...?AAIA=&pid=2196
14mm Thread, 19mm (3/4") Reach, 13/16" (20.6mm) Hex Size, Gasket Seat, Non-Resistor, Solid Terminal, JIS Height, Projected Tip, .032" (0.8mm) Gap, Heat Range 6
Seems it is the 21mm socket
Edited by lrostoke, 15 December 2009 - 08:51 PM.
Posted 15 December 2009 - 08:50 PM
Seriously though there are two sizes of spark plug sockets, it could be either, you should have them in your socket set.
a normal socket will be useless.
Posted 15 December 2009 - 08:51 PM
Posted 15 December 2009 - 08:56 PM
Posted 15 December 2009 - 09:13 PM
The Mini uses the "larger" spark plug size which requires a 13/16" deep socket. That would indeed be close to 21mm.
Mine uses the the smaller type plugs.
Posted 15 December 2009 - 09:37 PM
Posted 15 December 2009 - 09:40 PM
