Carbon Flip front sizes
Posted 18 October 2005 - 02:33 PM
My mini was in an accident and all the front panels have been damaged. I thought this would be the perfect excuse to fit a carbon flip front. However I have spoken to MiniSpeed who say that the fronts are the exact same measurements as a standard mini front.
This gives me a problem as I had to grind my standard arches to fit my wheels in. How would i go about cutting the carbon?
Or does anyone produce a carbon front that is made to fit bigger wheels without the need to modify it?
Thanks.
Posted 18 October 2005 - 02:57 PM
Posted 18 October 2005 - 03:05 PM
Posted 18 October 2005 - 03:42 PM
Posted 18 October 2005 - 05:52 PM
Posted 18 October 2005 - 11:03 PM
I dont really want a steel one as part of the attraction of a carbon / glass fibre front is that it will not rust. I'd prefere to do as much of the work myself as possible as im trying to keep the cost down.
I'm very tempted to go for the fibreglass option, I havnt found any advice on the net saying i cant grind it, only that the resulting dust could irritate my eyes and skin, which isnt a problem, however some advice from someone who has fitted one before would be good as I have not attempted anything like this before.
Posted 18 October 2005 - 11:13 PM
So Im going to be replacing the drivers side door, Both A-pannels, Scuttle pannel. And fitting a fiberglass flip front.
Cutting fiberglass is easy, you can cut the arches with a jigsaw with a fine blade on it.
Im just a bit unsure about flipfronts too.
Does anybody have a guide to doing the conversion, I understand that box rail need to be welded down the front of the car to act as a sway bar and reinforce the front end.
Anybody know if its possible to have the flip front clamp down with bonnet pins rather than those yukky looking clippy things across the scuttle and A pannels?
<|Ben|>
Posted 19 October 2005 - 08:18 AM
The bars you need are called brace bars and theyre about £30 from Minispped.
Posted 19 October 2005 - 08:22 AM
Posted 19 October 2005 - 08:28 AM
Edited by GuessWorks, 19 October 2005 - 08:28 AM.
Posted 20 October 2005 - 05:53 PM
Posted 20 October 2005 - 09:32 PM
Posted 21 October 2005 - 11:03 AM
Posted 21 October 2005 - 02:02 PM
Its just, Im really scared about the front end of me car, I dont know how rotton it is behind the front. theres filler in every joint!
:saywhat:
