You will need to fit the engine mounting/lower radiator bracket from the Mini, as the 1100 has an extended front plate with 2 mountings like an MG Midget or similar. The front plate doesn't matter, it won't be in the way of anything. The mounting at the clutch end fits exactly the same, but the 1100 one is thicker so will need to be changed. The remote gearchange is not identical to the Mini, but it will fit, it has a flexible metalastic 'sandwich' mount between remote & diff casing, so doesn't act as well as an engine stabiliser as the Mini remote. If you use 10" wheels you will probably need to change the final drive ratio, it's likely to be 4.1:1 which will give you incredible initial acceleration, but you'll have no top speed & fuel economy will suffer. A 3.4:1 is probably the best all-round diff with 10" wheels.
Edited by Sherlock, 10 December 2009 - 08:54 PM.
