Mpi Mini 10 Inch Wheels
Posted 10 December 2009 - 08:34 AM
I have a cooper sport MPI with sportspack fitted and was thinking about putting 10 inch wheels on it. Are there any on the market that will fit without having to change the brakes?
Posted 10 December 2009 - 08:43 AM
http://www.minispeed...ms-set-4-wheels
Paul.
Posted 10 December 2009 - 09:06 AM
Posted 10 December 2009 - 09:08 AM
Posted 10 December 2009 - 10:05 AM
Posted 10 December 2009 - 10:06 AM
Would the large offset wheels be a safe option i.e. would there be any issues with the strength of the wheel - this does look like an option because I do not want to be using spacers. Is there any other wheel options with the larger offsets to allow to without changing the brakes that look more like a sports pack wheel? I assume that the car would handle better with the 10 inch wheels
Thanks for the quick replies
Posted 10 December 2009 - 10:08 AM
Posted 10 December 2009 - 10:46 AM
I have an S reg MPI on 10's. I converted my brake setup to the MiniSport 7.9" 4pot Kit, the brakes are very good. I'm on 10"x6" Minators now from my original 12" Pepperpots, the handling is so much better. I'll pop up some pictures later if you want because i'm on my phone now.
Posted 23 March 2012 - 02:34 PM
You don't have to convert the rear setup, the 10 inch wheels will fit there ?
Posted 23 March 2012 - 02:52 PM
There are no mods needed to rear brakes of you already have discs.
Posted 23 March 2012 - 03:00 PM
Was thinking about the Yokohama A032R 167/70 but they will be a bit stretched indeed.
This kit is what I have in mind if it will fit my MPI : http://www.minisport...aliper_Kit.html
Because I want to go to a stage 3 in the future and I want to get the brakes right at once.
Edited by Driezzie, 23 March 2012 - 03:07 PM.
Posted 23 March 2012 - 03:17 PM
Posted 14 November 2024 - 07:04 PM
Awakening this thread as I am looking (not finding 175 50 13 tires...
I would go to 10" wheels on my MPI before I considered 12s...
Any good 10" wheel options for MPIs these days?? I recall some guy building a prototype wheel that would bolt right on - just before a big relocation that took me away from my mini for quite a while...
Posted 14 November 2024 - 07:31 PM
As said in earlier posts the safest option is to convert the front disc brakes to the Cooper S discs and fit 6x10 wheels.
This wheel linked below are 'Deep Dish' versions by Minilite and have the extra offset needed to fill the Sportpack MPi arches with Cooper S Disc brakes.
GENUINE MINILITE 6x10" ALLOY WHEEL. DEEP DISH
Offset ET-15, SPECIAL 70mm backspace made for the Japan market originally.
This gives 4.25" outer wheel edge from hub face.
Supplied with wheel nuts and centre caps:-
https://www.minispar...els/Wheels.aspx
BRAKE CONVERSION KIT 8.4" TO 7.5" DISC BRAKES
12" (and 13" MPI) wheel to 10" wheel running gear conversion kit. Less wheels
This kit will convert your 8.4 disc set up to the original Cooper S 7.5 discs to allow fitment of 10" wheels, kit includes discs, calipers, pads with split pins and drive flanges with new screws:-
https://www.minispar.../MSSK013MS.aspx
Or cheaper kit with Minispares calipers:-
BRAKE CONVERSION KIT 8.4" TO 7.5" BRAKES USING MS CALIPERS
This kit is as per MSSK013, but with Minispares calipers:-
https://www.minispar...-AJJ4028MS.aspx
Edited by mab01uk, 14 November 2024 - 07:42 PM.
