Stage 1..
22 replies to this topic
#16 clambert81
clambert81
  • 268 posts
  • Local Club: Crewes Missiles
Posted 10 December 2009 - 11:14 AM
you might have to change the needle in the carb as well.
#17 jaydee
jaydee
  • 8,565 posts
Posted 10 December 2009 - 11:16 AM
I think the minispares kit for 1275 with HIF44 carb will come with a BDL needle, which is a good starting point.
#18 finch661
finch661
  • 2,339 posts
Posted 10 December 2009 - 11:20 AM
i think the kit comes with it. though i just realised that i didnt change the needle in my hs4 when i went from a 998 to a 1275..... should i have done this?
#19 clambert81
clambert81
  • 268 posts
Posted 10 December 2009 - 11:33 AM
It would certainly be worth checking with Mini spares or mini sport on the correct needle as I suspect your mixture will be a little lean
#20 jaydee
jaydee
  • 8,565 posts
Posted 10 December 2009 - 11:34 AM
Oh you're lucky if you got the correct mixture without replacing the needle, you could roughly adjust idle but under load wouldnt work fine, usually on 1275s and 998s are used different profiles depending on engine specs. In some cases an AAA needle should work on both engines, surely a AAC (used on many standard 998 engines) wont.
About your next carb swap, HIF44 and HS4 needles arent interchangable, the HS4 uses 0,09" needles and the HIF44 uses 0,1" needles.
#21 finch661
finch661
  • 2,339 posts
Posted 10 December 2009 - 11:38 AM
to be honest, i can only notice a small difference in power between the 1275 and the 998, so maybe i should double check the needle. then again, i might aswell wait untill my stage one kit (i think tere is a kit for hif44 carbs with needle)
#22 jn1702
jn1702
  • 168 posts
Posted 10 December 2009 - 09:52 PM
I thought stage 1 kits used to come with a new needle and spring?
#23 jaydee
jaydee
  • 8,565 posts
Posted 11 December 2009 - 11:39 AM
Yes, they usually come with a new needle (which in must cases is useless) but not the spring.
