A Series Engine Numbers
85 replies to this topic
#31 Ethel
  • 25,922 posts
Posted 27 December 2007 - 03:03 PM
Gearboxes and diffs may have more info like manufacturing dates cast in
#32 pwhitehouse
pwhitehouse
  • 31 posts
Posted 29 December 2007 - 09:43 PM
I've slowly been compiling a list of engine numbers and associated features and I hope now got a fairly full list... but obviously not complete....
If you have anything to add then please post on the bottom of this and I will add to the sheet ( and then remove the post to keep it short and concise )
EDIT: Gold/Silver seal engine numbers, Link, Link 2.
Can anyone help,
I have just bought an a+ series 1275 metro engine, but dont know if it is unleaded or not, the numer by the thermostat housing is 12HA87AA 111188 ,
there is a number on the cyl head casting 26D5. any ideas which it is , and if its leaded, what is req'd to convert it to unleaded?, and at what sort of cost?.
Edited by pwhitehouse, 29 December 2007 - 10:03 PM.
#33 minimender
minimender
  • 1,589 posts
  • Local Club: M.M.M.
Posted 29 December 2007 - 10:05 PM
I've just bought a mini engined automatic trike, and need vto know a bit more about the engine.
Looking on your list the nearest number is 99H 791 which tells me it's an A series 998 with leaded head (v useful to know!) from a mini 74-on. My actual number is 99H 79 ZPH - is there any way I can use this to find out what year the engine was manufactured?
The nearest I can find to that is
99 = 998cc
H = transverse engine
795 = Denotes type of alternator, gearbox, etc the 5 was a guess instead of Z
P = code for carb, dizzy, crank vent system
H = Engine compression
Then engine No 1234 etc
#34 whitebuffalo
whitebuffalo
  • 60 posts
  • Local Club: Moala
Posted 17 January 2008 - 09:07 PM
In my '65 Morris Cooper it has a motor from some other car since I couldn't find any of the numbers on the list of engines. My engine has 12H157H1651
I'd say it is a 1275 high compression, but what does the 157 mean?
My other car is a '67 Austin Cooper S and it had a number glued to it (guessing the rebuilder placed a tag after skimming) and it has 7L931708 on it. The motor has tappet covers and a 1275 head on it. On the back where the fuel pump block off is there is only a cast place for the pump and one threaded bolt. Sure is a lively motor, but would like to know more about the two engines if anyone knows?
Edited by whitebuffalo, 17 January 2008 - 09:09 PM.
#35 ROD
ROD
  • 2,215 posts
  • Local Club: MCR
Posted 11 February 2008 - 07:09 PM
Could someone please help with this engine?
Engine no/ 12h/495f/8152
#36 tomsbluemini
tomsbluemini
    My Blue little monster
  • Area Managers
  • 1,498 posts
  • Local Club: LSMOC / Kentish
Posted 26 February 2008 - 12:09 PM
couldn't find the info on the engine numbes list, so if you're interested, my 1275 MPi engine, engine number 12A2K70368427
Hope this isof use to someone
Tom
#37 ad53ggz
ad53ggz
  • 384 posts
Posted 24 March 2008 - 02:13 PM
Hi my engine number i think is 99h997p 116051 is this then this one
99H 997 --> 127421 998 A+ L F C 2.95 FD, A series Main caps
from the list thanks.
#38 charlie_the_miniboy
charlie_the_miniboy
  • 314 posts
  • Local Club: ipswich maniacs mini club
Posted 10 April 2008 - 09:11 PM
i've got a 1275 (1330cc) block that has got a number, is there any other way of finding out what it's from and maybe an age???
the only number i can find is a casting number of 12G1279.....
does this mean anything
it's A series...
#39 edi57
edi57
  • 821 posts
Posted 21 April 2008 - 12:00 PM
I'm struggling to translate my engine No.:
99H3538-H323487
Can anyone help?
#40 dezshearer
dezshearer
  • 441 posts
  • Local Club: mini-chat.co.uk
Posted 21 April 2008 - 05:57 PM
Hi, my bored 1275 Block has no number on it =(
I was wondering if you can tell the age/year from its cast number?
WFM 1024.
Can anyone help me out here?
#41 dezshearer
dezshearer
  • 441 posts
Posted 04 May 2008 - 10:58 PM
Some more info,
i need to know the year so i know which kind of braided oil pick up pipe to get.
The filter housing has TAM 2097 stamped on to it... now.. these are different before and after 88, so does anyone know which years had TAM2097 stamped on them?
#42 JamesRance
JamesRance
  • 200 posts
Posted 11 May 2008 - 08:11 PM
Hey there
i have looked at the list i just wanted to make shore this is right my engine number begins with 12HC14AA, could anyone tell me if it is A or A+ and if its LEADED or UNLEADED, becuase the guy i bought my mini off didnt tell me ive been running it on unleaded and its been fine, but i want to make shore and not ruin my cylinder head lol
thanks
#43 liirge
liirge
  • 4,097 posts
  • Local Club: EDMC AND MMC
Posted 08 June 2008 - 01:07 PM
Hiya just wondering if i could get more information on my engine.
What i know at the moment is thats its:
1100, High Compression, out of a clubman. Is this the most ill ever know?
110H791AA135455
Kindest Regards
#44 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 10 June 2008 - 06:32 AM
Pretty much so yes...
Had an alternator and a std ratio A series gearbox on the bottom with a 3.44 final drive.
the *791* engine code was use pretty much across the board, so 85H791 (850) 99H791 (998) and 10H791 (1098), from 1974 upto the introduction of the A+ engine, and the specification of that engine didn't change much in that time.
#45 liirge
liirge
  • 4,097 posts
Posted 10 June 2008 - 06:14 PM
Cheers guessworks, i thought as much but worth a little try.
Hmm, interesting my engine has a dynamo fitted!!!
Alastair
