Hill Climb Car - Converting Into - Tarmac Rally Car
371 replies to this topic
#121 warning634
warning634
  • 489 posts
Posted 30 April 2012 - 09:31 PM
Hi all
Small update, located and fitted the clutch master reservoir (thank you to Retroracer 1275 http://www.theminifo...05#entry2409859)
And I plumbed in the oil breather pipes, just need another 19mm 3 way connector to finish it off.
Many thanks
Kevin
#122 ministar
ministar
  • 835 posts
Posted 01 May 2012 - 10:31 AM
Hmm... been looking at the location of the oil cooler.. and think i might put mine there. Do you run a thermostat atall?
#123 warning634
warning634
  • 489 posts
Posted 01 May 2012 - 12:43 PM
Hi ministar
Yes it seems like a good place for it, as I could not find another location for it that did not need any mods to make it fit.
As for a oil thermostat, no I'm not running one.
Kevin
#124 Tahiti Joe
Tahiti Joe
  • 663 posts
Posted 01 May 2012 - 12:54 PM
Really impressed with this, been following it for a while now! As soon as i pick my new car up, which hopefully will be today, i'll be taking mine off the road and starting its transformation into a stage rally car. Been starting too collect bits, getting expensive already! :P
Where abouts are you based? And most importantly, when are you planning on having it finished?! :D
#125 warning634
warning634
  • 489 posts
Posted 01 May 2012 - 07:38 PM
Hey there Tahiti Joe, I'm very glad you have been enjoying my build. I can't wait to see your rally mini when you start your build.
Well I'm based in Jersey in the channel islands, I need to have ready before July for a Multi Surface Rally, this rally is part of the criteria so I can ensure I get an entry into the main jersey rally in October
Let me know when you start your thread ok.
Kevin
#126 warning634
warning634
  • 489 posts
Posted 03 May 2012 - 07:26 PM
Hi all
Carried out a bit of work today.
A tool I ordered turned up, so I was able to secure the clip which holds the cv boot in place, I then toruqued up all of the bolts for the suspension and caliper.
Fitted the flexie brake line to the caliper and fitted the carbon metallic pads.
I took apart my other hardy spicer and replaced the uj part of it and cleaned it up, all ready for refitting with uprated bolts.
I have got next week off, so expect some more updates.
Kevin
Edited by warning634, 03 May 2012 - 07:28 PM.
#127 jonny f
jonny f
  • 1,485 posts
  • Local Club: Boxhill Mini Club
Posted 03 May 2012 - 07:39 PM
Are you fitting the mechanical fan, or just having the electric one? Had a look through the topic but couldnt see it anywhere.
Nice build!
#128 warning634
warning634
  • 489 posts
Posted 03 May 2012 - 07:48 PM
Nice build!
Hi Jonny f
I was just going to have the electric one, do you suggest that I keep the mechanical one on as well?
Glad you like the build.
Kevin
#129 jonny f
jonny f
  • 1,485 posts
Posted 03 May 2012 - 08:19 PM
I am doing exactly the same, so was just interested in the outcome. Read positive things about doing it and negative things.
The only time my engine ever got hot was sitting in traffic so thats why i am doing it, also helps with clearances and maybe gaining a little bit of power.
My research told me to ensure that the radiator has no gaps around it or as little gaps as possible to ensure all air goes through the rad rather than around it!
#130 Italianjoblofty
Italianjoblofty
  • 225 posts
Posted 04 May 2012 - 08:28 AM
Hey guys i've been in the same situation as you with the machanical fan. The way i looked at it was, there is no direct airflow to a side mounted radiator, which in itself is a problem. On a standard road car i would of thought the engine will be under very little stress there for not really requiring alot of cooling. But on a rally car i think you might have problems as you will be reving the nuts off your engine but there is still little airflow as you could be reving high but only in 1st, 2nd and thrid so not going quick enough to get the airflow. Again its down to a matter of opinion and proof in the eating of the pudding but i've decided to stick with the mechanical fan as the only downside is about 3bhp at high revs, which i think i can live with if it causes me less problems with over heating etc lol. By the way mate this is a very nice build and i have been following this thread. Keep it up :)
#131 warning634
warning634
  • 489 posts
Posted 31 May 2012 - 08:40 AM
Hi all
Big news! I have just dropped off my mini to the body shop for a full re-spray and repair the body work!!!! Can't wait, pictures to follow.
I'm sticking with the same colours.
Kevin
#132 warning634
warning634
  • 489 posts
Posted 03 June 2012 - 02:24 PM
Prep
Primer
#133 warning634
warning634
  • 489 posts
Posted 06 June 2012 - 08:46 AM
Ok some paint updates
It now has a white roof
And here with its new coat of java green:)
Can't wait to get it back!
Kevin
#134 warning634
warning634
  • 489 posts
Posted 11 June 2012 - 07:01 PM
Well guys it's back in the garage
I will have to give it a month, before I can really get stuck in, as I have to study for an exam.
Any way enjoy the pics
Kevin
#135 brad-the-bear
brad-the-bear
  • 1,114 posts
Posted 11 June 2012 - 08:22 PM
looks really good pal! great finish on the paint
    Bing (1)
