Hill Climb Car - Converting Into - Tarmac Rally Car
371 replies to this topic
#46 warning634
warning634
  • 489 posts
Posted 22 April 2010 - 08:49 PM
Hi everyone
right I have now welded extra metal plates onto the tie bar mounts, thanks GraemeC
I also started to play with my new Kad bias assy, also almost finished off my hubs, just need to order some new bolts and wheel bearings.
any way many thanks for your comments.
kevin
#47 CH007
CH007
  • 63 posts
Posted 22 April 2010 - 09:05 PM
Very nice work so far :(
I am just stripping my shell and snooping round for ideas and inspiration. I am not planning on rally but am planning on turbo lump so will need some serious strengthening as you have done.
Thanks for sharing and look forward to next update
#48 GraemeC
GraemeC
  • 7,437 posts
Posted 23 April 2010 - 07:35 AM
That looks good - much stronger than standard!
#49 andydlc
andydlc
  • 77 posts
  • Local Club: JMC&LCC
Posted 16 December 2010 - 12:52 AM
Updates? :thumbsup:
#50 warning634
warning634
  • 489 posts
Posted 16 February 2011 - 10:50 PM
Well it's been some time, and this has been due to purchasing a house so money and time are both in short supply.
But don't worry I don't have to sell the mini! Right update then, well the front subframe is now bolted on, with the front hubs with suspension temp in place. On replacing the top shock mounts I found rot behide the drivers side shock mount, so that will need to be repaired:( the rear sub frame is out stripped, gussets and seam welded just needs a coat of paint. I bought all new stainless bolts gor the rear subframe and uprated bushes. While on the subject of rear subframes one of the bolts which locate into lower part of the sill has snapped off, I have tried an easy out, with no joy. So what is the best way to remove either the snapped bolt or the rusted nut (oh by the way I have also removed the outer sill on ge same side which the bolt has snapped)
Yer I noticed that the l/h sill was looking a bit iffy, so I took an angle grinder to the under body seal, and found rot! So I'm now replacing my first mini sill, so any handy hints you can pass my way would be great.
Any more updates to follow.
Kev
#51 andydlc
andydlc
  • 77 posts
Posted 16 February 2011 - 11:17 PM
Come on kev, need a few more updates now I'm laying around not doing much!!
See you soon.. :)
#52 mini_matt_106
mini_matt_106
  • 591 posts
Posted 17 February 2011 - 09:58 PM
with sills attack it with a wire wheel on angle grinder! from whats left you should be able to judge the condition of the metal left and either replace or slap on some rust preventer and paint :xxx:
#53 warning634
warning634
  • 489 posts
Posted 18 February 2011 - 07:47 AM
Cheers andydlc, more updates are on there way. I hope you are recovering ok.
Mini_Matt_106 that is plan, there is a small little section of inner sill I need to replace by the heelboard.
What anti rust would you recommend?
Kevin
#54 mini_matt_106
mini_matt_106
  • 591 posts
Posted 18 February 2011 - 12:51 PM
i have used KRUST by hammerite before but there is probably something better out there, also red oxide primer is great stuff
#55 warning634
warning634
  • 489 posts
Posted 05 March 2011 - 07:47 PM
Hi all
Right then, well after buying some correct tools for the job (spot welder drill bit, aviation metal snips)
I have now managed to remove the sill. I also cut out the rot on the inner sill near the heelboard, and welded in some new metal. While I was attacking the rot near the heelboard I removed the lower subframe nut (as the subframe bolt had snap), I then welded some new metal to the inner section of the heelboard. I then welded a new nut to a repair washer, and then welded this to the inner section of the heelboard.
Then I fixed into place the new sill for a trail fit, and all is good.
I will be ordering a few more panels, clutch parts, head gasket etc
More updates to come
Kevin
#56 warning634
warning634
  • 489 posts
Posted 24 March 2011 - 08:55 PM
Right then, I have almost finished fitting the sill, I just have a little bit more welding to do, then grind down the plug welds, prime it then stone chip it. I also cut out the rot in the inner wing and inner sill.
This is the repair on the lower section of the inner wing, the welds have been cleaned up
Here is one of the brackets I had to make.
And here is the new sill all plug welded in place
And the rear subframe is now ready to be built up and fitted back on
Any way that's it for more updates soon.
Kevin
#57 dougie1142
dougie1142
  • 500 posts
  • Local Club: I.M.O.G
Posted 24 March 2011 - 11:08 PM
This is really lovely, once mines is back on the road i'd love to do something like this.
#58 warning634
warning634
  • 489 posts
Posted 25 March 2011 - 09:18 AM
Cheers dougie1142
It's slowly getting there, it's mainly the bodywork which has slowed the progress down. I should only have a section of the r/h inner arch I need to replace. I will be able to get it back on it's wheels soon.
#59 warning634
warning634
  • 489 posts
Posted 12 April 2011 - 09:20 PM
Hi all
Right then I have finished off the sill, and if I do say so myself for my first time in changing a sill I'm really happy with it.
Next on the list is the rear subframe which I have now seam welded and added some gussets.
I have bought a full stainless steel bolt kit from eBay. The rear arms I have cleaned up added new braided hoses.
I'm now just waiting for some alloy billet rear subframe mounts from DSN Classic.
I also fitted my grp A tie bars, so the ones I have removed will be for sale.
So it's these tie bars that will be up for sale.
That's it for.
Kevin
#60 Matrix
Matrix
  • 589 posts
Posted 13 April 2011 - 08:35 AM
Hi all
Those sills should be seam welded mate and not just tacked on >_< nice project keep at it, it's going to be a nice car when you are finished 8)
