Hill Climb Car - Converting Into - Tarmac Rally Car
371 replies to this topic
#316 InnoCOOPER
InnoCOOPER
  • 86 posts
Posted 05 April 2018 - 11:46 PM
Hi guys
Right then so lots of things going on, motor has been pulled and front subframe, pretty much every thing on the left hand side (and right side) has been changed, tie bars, bottom arms, hub, flexible brake lines, shock absorber, front subframe, steering rack, track rod ends, track rod arms etc etc
57858E05-E4B8-45EE-B6CA-F3AEDC7B8278_zps
33FFDEF3-FE3A-40FC-B907-E4626AE704CF_zps
D7FE08D4-43DF-45F0-9FDE-60BE9D67F664_zps
Also while the engine was out I decided to swap the old jack knight lsd to a much more modern MED NXG lsd, however once stripped down I also noticed that the pinion was pitted so a new crownwheel and pinion was also ordered from MED
3E7F1913-7470-4797-B14A-AED0B7242C44_zps
FDCF713C-A875-41BD-A5C8-F782618C2082_zps
A0625EF2-4D75-4D65-AC53-FEB93C6F1976_zps
I also took the time to rebuild the rod change, fitted a new rod and linkage stabilizer, rear bushes and upgraded the mounts to pilot ones to reduce the flex, I also installed the mini spares spring change.
8863525A-9982-432C-8D38-E704363F0D09_zps
055D0B2F-9E00-4F57-A41D-0D58415E185C_zps
Some nice new titanium bolts have been fitted
27EDCB6B-9C9A-4989-A077-09CD7A468BB2_zps
E7A766B3-0B17-44C9-86B5-A7265CCA7364_zps
F57B8CE6-EB3E-4FBC-80F3-17836C210948_zps
And lastly on Saturday the mini was taken to the body shop
BBB745B7-285A-43A4-A763-74F281F7FDFA_zps
So it wont be too long and it will be all back together and better then before
Kev
Kev how do you find the bias adjuster on the rod change.  I find it difficult to get reverse with it fitted.    Just getting mine prepped for the Hillclimbs in the standard class.
#317 warning634
warning634
  • 489 posts
Posted 26 April 2018 - 02:45 PM
Hi innocopper
Not actually used it as yet, Ive heard mixed reviews on it, so I dont know if its staying.
So the mini is about to be painted 😊
9FDDD15E-2975-411F-A752-A3BC85232DBB_zps
94711FAB-0712-47EB-B655-2C6E16B4A1FD_zps
5C20A774-7494-463B-9C05-F3780959A21D_zps
0158D1AF-1532-4A88-9525-6F705C15240E_zps
3BAB060E-DB7A-4EA9-B49B-3E058F5642E4_zps
I also have a new rear subframe, kad rear arms, so I can ensure that the rearend is all straight
Kev
Edited by warning634, 26 April 2018 - 02:46 PM.
#318 johnR
johnR
  • 2,322 posts
Posted 26 April 2018 - 07:55 PM
That's an immaculate front subframe - what's your deadline for having it all finished?
#319 warning634
warning634
  • 489 posts
Posted 26 April 2018 - 10:14 PM
Cheers johnR
I would like to have it all sorted by the end of May!
So I can compete in my first events of the year
#320 GraemeC
GraemeC
  • 7,472 posts
Posted 27 April 2018 - 06:45 AM
I'll be interested how the KAD arms hold up - I've always shyed away from them on my rally car as I've assume they'd be much more prone to getting bent.
#321 warning634
warning634
  • 489 posts
Posted 01 May 2018 - 10:37 AM
Wont be long until the mini is back, I got some more pictures from the bodyshop.
7543CC0C-65B3-4857-A3CB-254E3A78C817_zps
C1D74D5D-186F-413A-AEF3-B6A6D05EDFFE_zps
A2938810-B993-4D5B-9566-84A41E12FEAA_zps
And what do guys think of my new garage storage system
48D05F6B-B733-4F08-B367-3AF3F9FC936C_zps
So once its back I have a shed load to do...
#322 johnR
johnR
  • 2,322 posts
Posted 01 May 2018 - 06:25 PM
very cool garage!
#323 warning634
warning634
  • 489 posts
Posted 28 June 2018 - 10:45 AM
Okay
So it’s been a struggle but it’s all back together, completed a few events which have been hit and miss.
Follow my crash the first thing I change was the fuel tank, as it ripped open as we crashed and was spilling fuel not good.
5C275818-1D99-4CDC-9D9D-76A13DDF2D27_zps
7D8E9E69-A6CE-4EA4-99CB-A99779823C34_zps
Just have to remember to check the fuel levels, decided to replace the whole fuel system from MED.
Also change the position of the oil cooler
4D76404F-3C20-427F-B07B-C45DD0576B58_zps
To cover the fuel filler hole I got an arcangels carbon Kevlar blanking plate along with a parcel shelf
8AFAAD1A-E86E-4038-890E-DABF72446378_zps
B02FD2F1-C91B-43D4-895A-C92C5255723B_zps
New fire extinguishers fitted as well
2D7CCCBD-0663-41AC-ACCA-0F13AA269FF4_zps
Here are some pictures from the JIMF moonlight sprint and hillclimb
CA84665E-9D01-408E-998F-9C7161529D19_zps
367BE513-2831-40FD-8694-0538A173EF02_zps
21B9DFEB-9209-42C4-8E24-CDC8BFA7EC4B_zps
BAE6E878-03AE-4EC5-A384-070EEFF2B935_zps
CF1295F1-8754-480B-9C26-B75F36C5D3FF_zps
Then a few weeks back we had the l’etacq attack rally, and things did not go so well. Before the event I had a play with the hand brake and rear brakes and I must have just slight over adjusted the the rear brakes. On the first stage long uphill straight into a left 9 on the brakes and the back end locked up and it all got out of shape, held on and just clipped the front l/h arch and wheel which put the steering out ? got back to service de-adjusted the rears much better.
Pulled the wheel off at a longer service could not see what was bent so we adjusted the tracking. But the cars handling was bad. At lunch I thought I would have another look, and I spotted the bottom arm rose joint.
B2D1C7CA-54B2-447A-8C42-BF3B925CB79C_zps
50DA1C34-7866-4C4E-AB7B-A9018C5A01F1_zps
Did not have a spare and I did not fancy it snapping so called it a day.
So I have gone over the rear brakes and the kad bias and made some adjustments ordered some parts and will get to work once they arrive.
So hopefully things will get better and I will stop poking.
Kev
#324 Grant 111
Grant 111
  • 18 posts
Posted 28 June 2018 - 07:45 PM
Glad to see the car back out and competing, looks fantastic.
#325 warning634
warning634
  • 489 posts
Posted 17 July 2018 - 08:51 AM
Hi guys
Right I’m contemplating changing from 10” wheels to 13” due to the sheer lack of tyre choices for 10”
I have found a number of tyres that will suit what I need for both dry and wet conditions. What I’m struggling with is wheels, I need something strong etc as it’s for rallying any ideas??
I like the look of these Braid A13 wheels
352DE1CC-ABBA-4737-B674-FEB0400D95F0_zps
I can get them in the correct pcd 7x13 in ET11 which I think will be fine, I just know how they will look??
What do you guys think? Should I just get minilites
Kev
#326 warning634
warning634
  • 489 posts
Posted 17 July 2018 - 09:23 AM
So something like this
FE7E1A67-3BFE-4B0B-B058-9192DFB9B50F_zps
I reckon they look quite good ???
#327 keefr22
keefr22
  • 591 posts
Posted 17 July 2018 - 04:36 PM
Kev
Minilites every time for me Kev!
Keith
#328 DEPS
DEPS
  • 188 posts
  • Local Club: Carlton & District Motor Club
Posted 20 July 2018 - 02:24 PM
Hi,
Son and I just about to commence build of an asphalt/sealed surface rally car (as soon as we sell our 106 :D ). We likewise are thinking 13's due to lack of tyre choice in 10 & 12.
What tyres are you thinking of and in what sizes? We have been looking at Kumho's which seem to be available in various compounds and in wets.
Do like the look of those wheels, but obviously can not go wrong with Minilites, what minilites though as so many copies? My son has also been looking at some very sexy black wheels that he reckons are ok for motorsport, but as he is on holiday can not ask him the make at the minute.
I did start a thread on the Motorsport forum asking about wheels/ tyres/ brakes, but think that because I suggested 13's that put most people off from replying :D. Having done a number of single venues in the last 18 months or so in the 106, one thing I have learned is that tyres are critical.
I will continue to follow your thread with interest.
Cheers!
Dave
#329 keefr22
keefr22
  • 591 posts
Posted 20 July 2018 - 03:43 PM
I am certainly not any kind of expert on tyres, but we've got 13inch Yokohama A539's on the GT. We only managed to do a couple of dry hillclimbs on them, but my son & I both really liked them. They give plenty of grip, from cold and talking to other people using them they seem to be pretty good in the wet too. As I say though we only have very limited experience of using them.
Keith
#330 warning634
warning634
  • 489 posts
Posted 25 July 2018 - 08:42 AM
Hi,
Cheers!
Dave
Hey Dave
Size of tyres I was thinking 185/60x13 or 180/530x13
As for the tyres I'm looking at the, Kumho Ecsta C03 Tyre (medium compound) or Nankang AR-1 Tyre for the dry conditions. And wet conditions Kumho Ecsta C03 Tyre in a soft/super soft but the tread cut or the yoko A021-R as that's listed for wet weather. Kumho do have an actual wet tyre but I cant see it in 13".
I have emailed a few places for recommendations on tyres, so once I hear back I will let you know.
Kevin
