Hill Climb Car - Converting Into - Tarmac Rally Car
371 replies to this topic
#301 johnR
johnR
  • 2,297 posts
Posted 12 May 2017 - 10:14 PM
Great build - but it looks as though the sport is proving an expensive business for you! What would you say an average year would cost for someone wanting to start?
JohnR
#302 warning634
warning634
  • 489 posts
Posted 17 July 2017 - 08:48 PM
So a few weeks ago we took part in the L'etacq attack rally, only 8 stages which were changed after 2 runs, it was very relaxed 😎 and great fun.
We ended up 17th overall and we won our class, the mini ran like clock work.
Here are a few clips for you to enjoy
https://youtu.be/TUPC4xhzd-Y
https://youtu.be/4JJKPsshwes
#303 Grant 111
Grant 111
  • 18 posts
Posted 18 July 2017 - 06:04 PM
Great videos, the mini looked and sounded brilliant.
#304 warning634
warning634
  • 489 posts
Posted 21 July 2017 - 06:29 AM
Thanks very much 😀
#305 warning634
warning634
  • 489 posts
Posted 07 September 2017 - 12:39 PM
Hi Guys
Well its just over a month away until the Jersey Rally.  Pretty much every thing is all in order, but you always find work to do on mini's
I really noticed how bloody hot the exhaust tunnel was getting, so I have fitted a heat shroud which clamps onto the exhaust, so I hope that will soak up some of the heat.
I have also removed the steel rear boot and fitted a single skin carbon one and I have ordered some carbon/Kevlar door cards, which have the inserts cut in, so you can fit carbon levers directly onto the door latch.  So they should be down in 3 weeks along with some new DSN retro door handles.  6 Avon Cr6ZZ will also be ordered once my money comes in from a sponsor.
Fingers crossed we have ironed out any niggles, as we had no issues in our last event in July.
Oh does anyone know if the whole photobucket thing has been resolved, as I'm wondering how to link/show pictures.
Kev
#306 Northernpower
Northernpower
    Mr. 7-Port
  • 2,412 posts
  • Name: Graham
Posted 07 September 2017 - 01:30 PM
Hi Guys
Kev
From what I understand photobucket works at the moment but its not a long term solution. Like a lot of others I'm using imgur and I must say its a lot better and a lot faster.
Edited by Northernpower, 07 September 2017 - 01:31 PM.
#307 warning634
warning634
  • 489 posts
Posted 10 January 2018 - 12:46 PM
Hi guys
Well its been a while.
Our last rally did not go quite to plan 😜 we put the mini on its side, backwards down a tight lane, while bouncing off the banks. Which put an end to that rally!
But fear not, repairs have started, parts have all been ordered and its going to the bodyshop in a weeks time.
03655332-51EA-4EA5-974B-A4B0C4308E07_zps
942688DF-0431-404E-962F-663BFDD28EFB_zps
554F96A6-523D-41E0-BD35-A606A8F0A2C9_zps
#308 rich_959
rich_959
  • Just Joined
  • 568 posts
Posted 10 January 2018 - 02:20 PM
Ouch! Love this car - hope it's back up and racing again soon.
#309 jonny f
jonny f
  • 1,485 posts
  • Local Club: Boxhill Mini Club
Posted 11 January 2018 - 10:44 PM
Oh dear!
Glad youre going to repair it.
#310 rally1380
rally1380
  • 1,893 posts
Posted 12 January 2018 - 11:14 AM
Driver - It was a late call by the Nav.
Nav. - The Driver didn't listen
In all seriousness though, the main thing is everyone is ok and although it's a real shame, it does look as if it's a fairly straight forward fix.
I'm assuming the cage hasn't been damaged or touched at all?
Got the in car footage?
#311 warning634
warning634
  • 489 posts
Posted 12 January 2018 - 02:54 PM
Here you go.
https://youtu.be/PK70NimxxPA
#312 Pistonbroke66
Pistonbroke66
  • 89 posts
Posted 12 January 2018 - 03:15 PM
Looks like it just got a wiggle on some uneven surface.
Glad everyone is ok and good luck with the rebuild.
#313 rally1380
rally1380
  • 1,893 posts
Posted 12 January 2018 - 03:35 PM
Here you go.
that really is just bad luck eh.......... if in doubt, blame the nav.  Low sun couldn't have helped mind.
#314 warning634
warning634
  • 489 posts
Posted 26 February 2018 - 04:14 PM
Hi guys
Right then so lots of things going on, motor has been pulled and front subframe, pretty much every thing on the left hand side (and right side) has been changed, tie bars, bottom arms, hub, flexible brake lines, shock absorber, front subframe, steering rack, track rod ends, track rod arms etc etc
57858E05-E4B8-45EE-B6CA-F3AEDC7B8278_zps
33FFDEF3-FE3A-40FC-B907-E4626AE704CF_zps
D7FE08D4-43DF-45F0-9FDE-60BE9D67F664_zps
Also while the engine was out I decided to swap the old jack knight lsd to a much more modern MED NXG lsd, however once stripped down I also noticed that the pinion was pitted so a new crownwheel and pinion was also ordered from MED
3E7F1913-7470-4797-B14A-AED0B7242C44_zps
FDCF713C-A875-41BD-A5C8-F782618C2082_zps
A0625EF2-4D75-4D65-AC53-FEB93C6F1976_zps
I also took the time to rebuild the rod change, fitted a new rod and linkage stabilizer, rear bushes and upgraded the mounts to pilot ones to reduce the flex, I also installed the mini spares spring change.
8863525A-9982-432C-8D38-E704363F0D09_zps
055D0B2F-9E00-4F57-A41D-0D58415E185C_zps
Some nice new titanium bolts have been fitted 😊
27EDCB6B-9C9A-4989-A077-09CD7A468BB2_zps
E7A766B3-0B17-44C9-86B5-A7265CCA7364_zps
F57B8CE6-EB3E-4FBC-80F3-17836C210948_zps
And lastly on Saturday the mini was taken to the body shop
BBB745B7-285A-43A4-A763-74F281F7FDFA_zps
So it wont be too long and it will be all back together and better then before
Kev
Edited by warning634, 27 February 2018 - 10:11 AM.
#315 warning634
warning634
  • 489 posts
Posted 21 March 2018 - 09:49 AM
So things are moving along at the bodyshop, these are from a few weeks back.
B410FF78-12A7-4C48-AD1E-79FA15C34D23_zps
2441A768-7B8B-4D2D-AB1F-DCA37CFFC7D3_zps
1426128C-5D29-467B-918F-82C3B3C004C9_zps
ACC57348-B302-4CE6-8016-BED7B03F6C21_zps
And the other great thing is Im completely overhauling my garage, painted the floor and walls, and Im ordering a this lot with a corner section 😊
https://www.workshop.../APMSSTACK01SS/
