Hill Climb Car - Converting Into - Tarmac Rally Car
371 replies to this topic
#286 keefr22
keefr22
  • 591 posts
Posted 23 August 2016 - 11:04 AM
Great pics! I love that car!!
Keith
#287 Cavazzi
Cavazzi
  • 75 posts
Posted 23 August 2016 - 12:24 PM
Great onboard cam, a shame you were slowed by that blue thingy.
What tyres are you running? sounds like you loose traction quite a few times.
#288 warning634
warning634
  • 489 posts
Posted 05 September 2016 - 06:01 PM
So David Wells of SH Engineering has stripped the motor.......and.........the crank is scrap, thrust washers were onto the steel backing & ground their way into the crank, and the crack test revealed it was covered in tiny cracks.
The crank stroke is curiously 79mm with big end journals are 1.625 inch, so will be hard to find (and I have a tight timeline) So we are are going race spec crank with standard stroke, Saenz con rods, Omega lightweight pistons, camshaft, followers, light weight clutch plate, grey cover, bearings, oil pump, water pump, gaskets, seals etc.
So let the rebuild start :) can't wait
Kevin
#289 warning634
warning634
  • 489 posts
Posted 06 September 2016 - 08:02 PM
Parts have arrived today:-
2 x sparco 6 point harnesses
full set of 4mm black mudflaps
2 x cable pulls for the cut offs (need replacing)
So 37 days to go!!!
#290 phil hill
phil hill
  • 616 posts
Posted 06 September 2016 - 08:38 PM
https://youtu.be/pGtczx9wnhc
And thats just one SS?
Damn you have to keep your wits about you!!
Phil.
#291 warning634
warning634
  • 489 posts
Posted 30 September 2016 - 07:34 PM
https://www.facebook...41332689265454/
136.3hp @ 6700 rpm
Just got to fit it now :)
Edited by warning634, 30 September 2016 - 07:35 PM.
#292 warning634
warning634
  • 489 posts
Phil.
Yes thats just one SS
#293 keefr22
keefr22
  • 591 posts
Posted 30 September 2016 - 07:46 PM
136.3hp @ 6700 rpm
Nice!!
#294 warning634
warning634
  • 489 posts
Posted 20 October 2016 - 12:08 PM
Well this years rally, was as they say character building!
The motor was absolutely spot on, pulled out of corners, no bogging down....and does she rev!!
So the issues where other items, the fan lost all of its blades on the first stage and took the rad out, so that was it!
But we managed to fix the mini for Saturday's trophy rally, which runs be hide the main event. But, on our forth run through the stage the inner hardy spicer, gave up!
I will post up some some pics, for now here are some videos.
10207738699841361
https://youtu.be/YTVEZJBceS8
https://youtu.be/CelAd_5mkQI
https://youtu.be/ISVhsNrF6Vo
Edited by warning634, 21 October 2016 - 10:38 AM.
#295 warning634
warning634
  • 489 posts
Posted 29 October 2016 - 08:06 AM
So I will be ordering uprated hardy spicers and drive shafts from swiftune.
Also time to replace wheel bearings, ball joints and a few other bits
#296 warning634
warning634
  • 489 posts
Posted 08 November 2016 - 08:50 PM
Don't you just love it when new parts turn up
DD8E2815-BDBF-4608-9569-042EFCAE85CB_zps
Edited by warning634, 08 November 2016 - 09:13 PM.
#297 rally1380
rally1380
  • 1,893 posts
Posted 09 November 2016 - 09:19 AM
Not when they come with a hefty invoice........ >_<
#298 warning634
warning634
  • 489 posts
Posted 19 November 2016 - 07:47 PM
Okay so I fitted one side (the bust side) with my new swiftune hardy spicers, drive shafts and new hubs.
So here is the bust hardy spicer, once removed from the car. I was worried about any damage to the gearbox case, but luckily no such issue.
66CDD6A5-2B6B-40FC-B96B-6A4182B53A07_zps
I then started building up the shafts to the new cv joints and hardy spicer joint
0DCD2EDA-078B-43A4-A023-BD32D17C764D_zps
6BBB06BD-4C8C-4E99-8FDF-AB681E8AF053_zps
C4C442E5-36F8-49BF-93B3-FA72369C606E_zps
4FC1A99B-3AE5-4D4D-9503-D62667D6314A_zps
810BF290-6666-47E4-828C-AF3AE73E02B5_zps
Not going to break these
22A32969-3A4F-4F3C-A79E-3EDBEF230495_zps
Just need to order some new steering arm bolts and dowels and I can button this up!
Cheers Kevin
#299 warning634
warning634
  • 489 posts
Posted 15 March 2017 - 07:54 AM
Hi all
A few further updates, I decided to replace my radiator to nice radtec alloy rad with an updated rad cap, along with that a carbon fiber 2 bladed fan from carbon weezle.
1398B971-37C7-4980-B1AE-DF21FCB9CC92_zps
9C51BF48-BEC9-44FC-AB5B-A484899D6764_zps
I have also ordered some tarox drilled discs, mini spares 4 pot calipers and new carbon metallic pads, so I will keep you updated when they arrive. I will be also replacing my rear wheel bearings as well, as my front ones have just been done.
Kev
#300 warning634
warning634
  • 489 posts
Posted 11 May 2017 - 09:37 AM
Hi all
So I have replaced the rear wheel bearings, which I was shocked to see were still the very old ball bearing type! And very nice color of grey for the grease😫 So we know have brand new tapered rear wheel bearings in place.
Along with these I also upgraded the front brakes to mini spares 4 pot calipers, carbon metallic pads and tarox discs.
D0A66719-B7E6-420C-95C3-332014BADB28_zps
B0E1D10F-CFF2-4D59-BABF-2C3B13EC2CAC_zps
The h3 spotlight bulbs have had an upgrade to a nice HID racing kit from demon tweeks, bit of a faff as I thought I could squeeze the ballasts under the lamp pod, but they are too big, so I have mounted them to the underneath of the bonnet with no issues.
61E92A22-BF89-4048-82DE-3747917A17CC_zps
Going to have a look at the idle jets on the webers, as the plugs are fouling up when on idle but no issue when giving it some beans.
I have a few events coming up, a night time classic sprint and hill climb, and then a one day rally.
Cheers kev
