Hill Climb Car - Converting Into - Tarmac Rally Car
371 replies to this topic
#16 warning634
warning634
  • 489 posts
Posted 02 December 2009 - 08:13 PM
Hi all
So i have started to cut out the bulkhead, so i can make a new miglia style bulkhead
Next I will start to make a template for the new bulkhead :crazy:
Any one know where i can get hold of new bushes/mounts for a rear antirollbar, i have been told it's a janspeed antirollbar
And check this out, what the hell are these bolts sticking out of the head (next to the spark plugs)??
oh and some new bits ;)
Kevin
#17 GraemeC
GraemeC
  • 7,437 posts
Posted 02 December 2009 - 08:48 PM
ARB bushes are possibly the same as engine steady bushes.
The bolts in the head are blocking up ports for an emmissions reduction system that pushed air in to the combustion chamber. You don't see those heads often (not that they are anything special in terms of performance).
#18 rosco454
rosco454
  • 908 posts
Posted 03 December 2009 - 04:01 PM
Forgot to upload the photos so il get them later but from the front edge of the bulkhead in front of the tower bolts is about 430mm to the back of the box/inside of the dash and from the carb clearance channel in the centre is about 380 or so.
Hope that helps,Ross.
#19 warning634
warning634
  • 489 posts
Posted 08 January 2010 - 11:37 AM
Tomorrow i pick up my new Mulit Point roll cage for the mini.
Update and pictures to follow.
Kevin
#20 Tim1970
Tim1970
  • 394 posts
Posted 18 February 2010 - 12:31 AM
Any updates on this at all?
Really interested to see what you're up too.
Great looking car.
#21 warning634
warning634
  • 489 posts
Posted 18 February 2010 - 02:40 PM
Great looking car.
Hi Tim1970
Not much has happened of late, I do now have the multi-point rollcage to fit and I just need to remove some bracing that was welded in and I have a very good mate who will make my custom full length air box, I also picked up a nice dash as well cheers Lewis.
I have also received in the post two large orders from minispares and Peterlloyd rally, we are talking:- yellow spot suspension cones, uprated drive flanges, uprated steering arms, carbon metalic pads, seals and S.S brake pistons, revotec electric fan kit, uprated lower suspension bolts, lowered top shocker mounts, 2x Corbeau sprint seats, nicky grist 4 point harnesses, side alloy seat mounts, 2.0ltr hand held fire extinguisher and 2.25ltr plumbed fire extinguisher, I think thats about it :dontgetit:
I will be at my garage tonight so I will take some pictures.
Nexted on the order list a ETB Digidash, Longacre switch panels, ETB circut breakers, alloy rad, spax motorsport shocks, revotec hoses, heated front screen.
Things are going to shift into high gear now.
cheers
Kevin
#22 lewis
lewis
  • 2,322 posts
  • Local Club: Mini Club Jersey
Posted 18 February 2010 - 02:55 PM
wish i had as much money to spend on my mini :genius:
glad you like the dash kevin, looking forward to seeing your mini at easter!
also i may need a sit in those seats of yours, im torn between the the corbeaus and the sparco revs :dontgetit:
lewis
#23 mini93
mini93
    He's just too casual!
  • 8,615 posts
Posted 18 February 2010 - 02:57 PM
look forward to seeing pictures :dontgetit: hope u gather pace now its getting slightly warmer too :genius:
#24 Tim1970
Tim1970
  • 394 posts
Posted 18 February 2010 - 09:06 PM
Very nice, great parts you've been gathering.
Look forward to the pictures all sounds great :unsure:
#25 warning634
warning634
  • 489 posts
Posted 19 February 2010 - 10:49 AM
Hi guys, thanks for showing your interest in my project, here are some pictures.
cheers
kevin
Edited by warning634, 19 February 2010 - 10:57 AM.
#26 warning634
warning634
  • 489 posts
Posted 20 February 2010 - 03:28 PM
Hi guys
I did a dry run of fitting the roll cage, oh man I had no idea how much work was involved in fitting a multi-point roll cage. Has any one got any advice or things to watch out for when fitting.
Any way here are some pictures,
cheers
kevin
#27 Mini Basher
Mini Basher
  • 424 posts
  • Local Club: Mini Foresters
Posted 21 February 2010 - 02:28 AM
Thats some really nice kit you've got there, the car is definately starting to move along now, can't wait to see the finished article, keep at it
Andy
#28 Mini-Mad-Craig
Posted 21 February 2010 - 02:39 AM
Brilliant mate, enjoying this!
#29 warning634
warning634
  • 489 posts
Posted 24 February 2010 - 02:13 PM
Hello all
Should be doing some more work over the next fews days. I think I will go and purchase a Mig welder as well...
I have also ordered some more bits today from MiniSport and Rallynuts:-
Monte Carlo heated front screen, grooved hi-spec cooperS discs, sportx rally exhaust system, weld in OMP seat mounts, OMP spare wheel holder, ring eye bolts and FIA spec plates for the 4 point harnesses.
So I will mock up the rest of the rollcage and get that ready to weld in the plates and the other multi-point sections, then I should be ok to get the seats in to get the seat mounts welded in >_<
Kevin
#30 mini_matt_106
mini_matt_106
  • 591 posts
Posted 24 February 2010 - 06:44 PM
hi lovely car its so nice and oldschool! the different bulkhead looks like an interesting idea i've never seen that before! how does this affect the dash? does it bring the bulkhead out as far as the dash rail? would you still be able to fit clocks to the dash rail? keep up the good work ;)
