Hill Climb Car - Converting Into - Tarmac Rally Car
371 replies to this topic
#256 warning634
warning634
  • 489 posts
Posted 16 October 2013 - 03:21 PM
Not sure what damage has been caused inside te box. Not that it matters as I have a quaife dog-box to fit now and I think I will send the entire unit over to swiftune for a re-build this winter.
#257 warning634
warning634
  • 489 posts
#258 BronkoMini
BronkoMini
  • 1,484 posts
  • Local Club: Mini Fixers
Posted 17 October 2013 - 10:08 AM
Just read the build, your work is truly inspiring, just a shame about the engine
#259 Goacher65
Goacher65
  • Just Joined
  • 161 posts
Posted 29 October 2013 - 10:08 PM
A few more bits turned up, like these weld in seat mounts
Any way cheers for now.
Kevin
I know its a little while back, but can you remember who sold the weld in seat mount kit? Is it mini specific?
Was hoping to keep my restoration to FIA spec so I have the option of using it in competition if possible at a later date...
#260 warning634
warning634
  • 489 posts
Posted 27 February 2014 - 10:12 PM
Hey guys
Looks like I'm going to need a new motor :(
I pulled the motor out and stripped it down and I was thinking that I only damaged the gearbox........nope.
There was more fretting on the crank and flywheel, damage to the con-rod, piston and block which was caused by the dizzy shaft. So with all that needing replacing, I think that a new motor is on the cards!
Who to use, I'm thinking of a short list MED, swiftune, Selby engineering or Harris Motorsport?
Can I have your thoughts on these builders, and maybe some recommended spec for around £3,000
Kevin
#261 keefr22
keefr22
  • 591 posts
Posted 27 February 2014 - 10:51 PM
Oh dear, that's a shame. We've got a Harris motor in ours, not sure what the spec is, my son has the details somewhere. It's a 1293 on a single 45 & runs very nicely (well it did before we took the car off the road to build it properly to rally spec.& undo the bodges undertaken by the 'builder' of it!) The car came with sheets showing 101 bhp on a dyno run just before we bought it. Good thing I can say for Mr. Harris was that my son phoned him just after we got the car & asked him if he knew any details about the engine - he remembered quite a bit & helped us build up a spec for it, as the seller didn't have much info at all. My son said he was very friendly & helpful in the call, so should the worst happen with our motor, we'd likely go back to him...!
Good luck!
keith
#262 warning634
warning634
  • 489 posts
Posted 28 February 2014 - 10:48 AM
Cheers Keith
Here are some pics of the damage.
Crank fretting.....scrap
CD7CA48A-B268-4D5D-B345-603BB4D9C4BE_zps
Damage to piston skirt and block
6278A28F-E2D3-4867-AA52-B0753869D038_zps
Damage to conrod
A3401C7C-D1A9-449F-B58A-B0E2D77E9CA9_zps
Now I know that I will need to replace the pistons and conrods, but what is your thoughts on the block and crank
Kevin
#263 warning634
warning634
  • 489 posts
Cheers Keith
Damage to conrod
Kevin
#264 keefr22
keefr22
  • 591 posts
Posted 28 February 2014 - 12:14 PM
Personally I've no idea sorry, not a good enough engineer I'm afraid. Hopefully there's people on here that'll be able to help. Maybe you could e-mail the pics to the engine builders you're thinking of maybe using & ask them?
Really sad pics though....
#265 oakrichardson
oakrichardson
  • 55 posts
Posted 28 February 2014 - 01:29 PM
would recommend swiftune, good quality and easy to deal with.
#266 GraemeC
GraemeC
  • 7,438 posts
Posted 28 February 2014 - 07:07 PM
I would've said rod bolts and crank need replacing, the rest should go again with a bit of careful dressing back of the damage (based on what can be seen in the photos).
Edited by GraemeC, 28 February 2014 - 07:08 PM.
#267 cradley-heathen
cradley-heathen
    Metro-Man
  • 2,481 posts
  • Local Club: spearmint rhino
Posted 28 February 2014 - 11:04 PM
thats a lovely looking machine you have got there, shame about the incident with the engine but these things happen. at least you had some fun first.
#268 warning634
warning634
  • 489 posts
Posted 01 March 2014 - 04:48 PM
Cheers guys
I think I may go for a new flywheel, crank, pistons amongst other things ;)
Don't you just love making lists of mini parts
#269 jonny f
jonny f
  • 1,485 posts
  • Local Club: Boxhill Mini Club
Posted 01 March 2014 - 07:40 PM
I'd say the rod is safe, a good time to lighten and work them!
#270 warning634
warning634
  • 489 posts
Posted 16 July 2014 - 02:15 PM
Hi guys
So here is the spec of my motor which I'm picking up in a few weeks :)
1380 MED race engine complete with Jack knight dogbox
Richard Longman custom split 45dcoe carbs
7cc dished pistons
MED offset rac e38/31 cyclinder head,11 stud, sccr springs, titan roller rockers,AGSP cam and belt conversion.
1275 gt Crankshaft, 1505 Ni-temp/cross drilled/bladed/wedged/ Balanced
cooper s 521 polished/lightend/balanced rods
Ultra light flywheel and back plate
Gearbox
jack knight evolute DOGBOX, cam & pawl LSD, straight cut gears, jack knight equal length drive shafts...
What do u think?
