Hill Climb Car - Converting Into - Tarmac Rally Car
#196
Posted 17 September 2012 - 10:04 PM
#197
Posted 17 September 2012 - 10:06 PM
#198
Posted 19 September 2012 - 11:47 AM
Nice piece for you, it's very lighter
http://www.gt2i-comp...c-2_131.html#FP
#199
Posted 19 September 2012 - 04:39 PM
#200
Posted 19 September 2012 - 06:03 PM
keep up the good wook, dave
#201
Posted 20 September 2012 - 06:40 AM
Only 20 days left! Aaaaaahhhhhhgggggg
Well last night I fitted the fuel tank and the new fuel cap, engine bay wiring is almost done same as all the internal switches.
Tonight I will fitting the cv boot clips and once that is done I can then torque all the bolts on that side.
Pics to follow.
Kevin
#202
Posted 20 September 2012 - 06:43 AM
Are the sliders the kit from plastics4performance?
Hi jaydee
The slider kit is from
http://www.acwmotorsportplastics.co.uk/
Kev
#203
Posted 26 September 2012 - 06:44 AM
But as yet no oil pressure, so I will have to play around with the engine tomorrow.
Just have a little bit more to do on the wiring ( headlights, washers etc)
I also changed the clutch arm and I'm so glad I did!
I noticed that the clutch adjuster bolt was pretty much fully adjusted due to the bent arm and as well as that check out the extended pin
I'm guessing that this was done due to the fact that the arm was bent and the pin was not long enough to operate the clutch.
Any way when I get oil pressure tomorrow I will be starting it up.
Kevin
#204
Posted 26 September 2012 - 12:47 PM
It was around 64-70 psi while I was cranking it over.
So lets see if it starts;)
Kevin
#205
Posted 26 September 2012 - 01:23 PM
So, did it go....??
Keith
#206
Posted 26 September 2012 - 08:11 PM
Phew!! You had me holding my breath too!!
So, did it go....??
Keith
Your telling me, I was thinking oh great engine out new oil pump and I only have 2 weeks till the rally!
Not today, tomorrow is the day when I shall try and fire it back into life and I have all day Friday off work as well:)
Kevin
#207
Posted 27 September 2012 - 07:02 PM
Glad its got oil pressure though.
#208
Posted 27 September 2012 - 08:25 PM
Doesn't it need running in, Kevin?
Well it's alive :)
Took a bit of cranking over to fill the carb up but it finally sparked into life;)
No it does not need running in, I only changed the head gasket and the clutch, so I jut got to run it up to temp re-torque the head bolts and do the tappets.
Time to plug in the laptop now, wish me luck
I have tomorrow off work, which is great as I now got loads of stuff to do.
Kevin
Edited by warning634, 27 September 2012 - 10:02 PM.
#209
Posted 27 September 2012 - 09:04 PM
Good luck with the laptop!!
Keef
#210
Posted 29 September 2012 - 07:26 PM
Right where to start, all of the wiring is now done and every thing works. Here is a list of what I've fitted:-
Heated screen
Seat bars
Red top 25 battery & cover
Drivers side door
Bolt check
So tomorrow I will fit the mud flaps, adjust and bleed the clutch. Then I need to get two brake lines made and then get the suspension set up. Less than 2 weeks to go.
Kevin
