Hill Climb Car - Converting Into - Tarmac Rally Car
371 replies to this topic
#166 warning634
warning634
  • 489 posts
Posted 01 August 2012 - 10:20 PM
Looking good, like the high-torque starter too... thinking I might get one aswell... nice and shiney!
I got mine from minispares, just ignore the note on the website that says that the flywheel housing needs to be modified, I spoke with Andy from minispares and it does not apply to this starter.
Kevin
#167 warning634
warning634
  • 489 posts
Posted 05 August 2012 - 10:31 PM
Hi all
I spent a few hours on the mini today, got the following little jobs done:-
Wired up my new led number plate lights.
Plumbed in the washer jet pipeing.
Made some adjustments to a spacer on my alternator.
Elongated some holes in the passages door so I could fit the exterior handle and then fitted the door.
Changed the weber throttle linkage for a much cleaner one a had floating around.
It crazy how long it takes to get these little jobs out of the way.... Oh and I ordered my new polycarbonate windows;)
Kevin
Edited by warning634, 06 August 2012 - 08:21 AM.
#168 warning634
warning634
  • 489 posts
Posted 26 August 2012 - 09:18 PM
Hi all
I have been in holiday mode for the last two weeks, but I did managed some work on the mini.....but I really need to pull my finger out know!! My entry for the rally has been sent in.
I ordered a few bits for the remote gearchange, as I was having issues with a very tight gearchange. So I removed the selector section stripped it down, re-greased and rebuilt it. So I installed a new kad quick shift and remote gear lock out unit,
My new polycarbonate windows turned up, so I got to work fitting them.
Be ready for many more updates.
Kevin
#169 RandyBMC
RandyBMC
  • 58 posts
Posted 27 August 2012 - 02:49 AM
I love this car - good work! Can't wait to see more.
#170 CobraV8
CobraV8
  • 991 posts
Posted 27 August 2012 - 08:01 AM
Looking at your starter motor I now wonder if I fitted mine wrong. In my case it sticks forward, so i cut a bit of the body away. Itis still covered by the grill tho.
#171 warning634
warning634
  • 489 posts
Posted 27 August 2012 - 08:57 AM
Cheers for the comments, I'm glad you are enjoying the build.
Not sure, I thought that it could only be fitted one way! As fitting it the other way would put all the wiring connections towards the engine.
Kevin
#172 CobraV8
CobraV8
  • 991 posts
Posted 27 August 2012 - 09:48 AM
I will have a look at mine in the morning. I could only make mine fit one way. Maybe it is different. It came off a clubman bodied speedway saloon, so had a bit more space than in my car.
#173 Sourire
Sourire
  • 18 posts
Posted 27 August 2012 - 11:36 AM
Nice car ;)
where do you find your bulkhead grommets ?
#174 warning634
warning634
  • 489 posts
Posted 27 August 2012 - 02:11 PM
Nice car ;)
The one for the battery cable is
http://www.demon-tweeks.co.uk/motorsport/battery-cable-connectors/longacre-battery-through-panel
And here are the grommets
http://www.demon-tweeks.co.uk/motorsport/hose-fitting-accessories/seals-it-firewall-grommet-seals
Kevin
#175 Sourire
Sourire
  • 18 posts
Posted 27 August 2012 - 02:39 PM
Many tks
#176 warning634
warning634
  • 489 posts
Posted 29 August 2012 - 09:03 PM
More work carried out, got the bonnet, lamp pod and arches back from paint.
Enjoy
Kev
#177 Willy_sa
Willy_sa
  • 93 posts
  • Local Club: MOCSA
Posted 30 August 2012 - 11:46 AM
That Looks Great!
#178 ministar
ministar
  • 835 posts
Posted 31 August 2012 - 07:55 PM
Magazine feature?? Hmmm I would contact Mini Mag!
#179 miniQ
miniQ
  • 497 posts
Posted 31 August 2012 - 10:22 PM
Nice.
What type of paint was used?
#180 Spitfire12
Spitfire12
  • 102 posts
Posted 31 August 2012 - 11:12 PM
Looking really good, nice one!
