ok so my mini crabs, its something that has always annoyed me and quite frankly iv had enough of it and have started a project to reserect the original-ness (aka not crabbing)
So i got a long peice of string, measured the length from the corner of the rear to the front subframe for both left and right sides, to see if the subbies where alligned properly. to my suprise they were!
ok so something is either not sitting right or is bent! after closer inspection on the rear subby i have noticed . . The gap between the hub shock absorber stud to the lef of the subbie is (x) for the right hand side. and for the left, is (x / 2) lets say.
I hope you bright sparks might see where this is going. Rear radius arm replacement time? If someonce can elaberate on my idea, just to see if im on the right lines would be great. Thanks guys . . n girls of course
ERic
