Tiny air bubbles in engine oil?
Posted 15 October 2005 - 08:30 PM
It doesn't look like water as there is no sign of emulsion anywhere and the water in the rad is fine. I changed the oil and filter in case the oil was knackered but the tiny air bubbles are back. Just somehow doesn't look right.
Apart from that the engine seems to run as sweet as a bag of nuts with no other symptoms.
Could the head gasket be on its way out or some other problem?
Posted 15 October 2005 - 09:33 PM
Posted 15 October 2005 - 09:38 PM
Posted 15 October 2005 - 09:42 PM
Posted 15 October 2005 - 10:18 PM
Posted 15 October 2005 - 10:56 PM
Posted 15 October 2005 - 11:07 PM
Oil does boil when exposed to its limits but it is more likely to be fuel boiling out of the oil. Petrol, being a solvent, disolves in the oil when cold( fuel pump leak?), when it is then heated, the petrol starts to boil causing lots of tiny bubbles.
Fuel saturated oil is not a good thing as its difficult to pump. It foams in the pump itself, not to mention that it will foam on the journals at the higher localised temperatures, leaving lack of lubrication. Seveare cases will destroy the engine.
If you could take a sample of the oil in a scientiffic jar then heat it until the petrol started to boil off, it would most likely resemble a glass of Guinness ( not suggesting you actualy do this)
Posted 16 October 2005 - 12:24 PM
Posted 16 October 2005 - 12:48 PM
Fuel pump leak???The oil is 20/50 Unipart green and was only changed last weekend as I needed to eliminate the oil being knackered so you may have a point with the fuel. How would this get mixed with the oil though?
Posted 16 October 2005 - 12:59 PM
Posted 16 October 2005 - 06:36 PM
Reckon I'll go and get some beer myself.
