Mikalor clamps are much easier to use than jubilees .. they also don't cut into the hose as much and are available in S/S
Edited by gazza82, 02 October 2020 - 04:09 PM.
Posted 02 October 2020 - 04:08 PM
Posted 06 December 2020 - 06:59 AM
Posted 06 December 2020 - 07:43 AM
Put it on the rad first, then connect it to the water pump once in.
Posted 06 December 2020 - 07:47 AM
Posted 06 December 2020 - 08:52 AM
Posted 06 December 2020 - 09:55 AM
It does depend on the car.
as some had two piece cowls for a reason.
bit full assemble rad and cowl and bottom hose. Place in car. Attach hose to water pump. Do up mounting bolts for rad.
ps make sure the fan is on the correct way. Smooth side to engine.
Posted 06 December 2020 - 03:39 PM
Posted 06 December 2020 - 03:45 PM
Cheers nick! When you it depends on the car, do you mean just different production tolerances?
Age. Model etc they are not all the same. Also there are different fan spacer configurations bottom rad mounts and top rad mounts.
Posted 06 December 2020 - 04:32 PM
Cheers nick! When you it depends on the car, do you mean just different production tolerances?It does depend on the car.
