Indicator Light Flashing Rapidly
4 replies to this topic
#1 Wippet
Wippet
  • 147 posts
Posted 26 November 2009 - 04:15 PM
Mini Cooper:
1998:
Indicator light flashing rapidly. I thought I had fixed this problem by changing the bulb (which was blown) on the front of the car. After changing the bulb both indicators worked. Next day its back to flashing rapidly with the front bulb out, however it seems to be intermittent sometimes its alright but mostly not.:
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 26 November 2009 - 04:17 PM
so are your bulbs now ok and working :D ?
#3 cooperdan
cooperdan
  • 3,729 posts
  • Local Club: N/A
Posted 26 November 2009 - 04:22 PM
I would have said your relay is going/ or fuse
#4 v21ash
v21ash
  • 421 posts
  • Local Club: HumbersideMiniClub.co.uk
Posted 26 November 2009 - 05:12 PM
Indicators flash rapidly to tell you you've got a bulb out, if their falshing rapidly and all the bulbs are working then i'd say it's the flasher relay.
As it's intermittent it's more likely to be a duff connection on one of the bulbs, first thing i'd do is take all the bulbs out clean the connections and put Vaseline on them, if that doesn't cure it then look at the relay.
#5 steble
steble
  • 750 posts
  • Local Club: chichester mini club
Posted 26 November 2009 - 10:50 PM
yer you'll prob find its a wire has broke somewhere or something is shorting
