Waxoyl Clear......a Question
2 replies to this topic
#1 mk=john
mk=john
  • 1,167 posts
  • Local Club: Milton Keynes Mini Club, Mini Cooper Register
Posted 21 November 2009 - 10:25 PM
Hi
I started to apply clear waxoyl the the under side of my car. However, when applied, it goes on and looks sort of yellow and a little lumpy. Even when I thinned it with white spirit, the same thing happenned. I also placed the can in a bucket of hot water for at least 30 minutes.
Should this be happenning? if so, does it actually dry so it is clear, or will it just look yellowy?
I am using the pressure can with a plunger on the top. Is there a better type of wax which actually is clear when applied, and how is this done? When the spary was coming out, it was more like a sqirt than a fine spary. Should it spray a fine mist?
I have wiped away what I have done, ready to start again.
Can anyone please shed some light on this?
#2 welshdan
welshdan
  • 643 posts
  • Local Club: ?
Posted 21 November 2009 - 11:09 PM
Hi
it will dry yeallow ish. it wont be crystal clear. what i do is hammerite the underside, followed by underseal (with waxoil) and then hammerite again. just because i do this it doesnt mean it is right
the aplicator squirts the waxoil, mainly to get it into box sections, eg there are only 3-4 rust proofing ports on mini sills, therefore need to squirt it into the sills to get decent coverage
Edited by welshdan, 21 November 2009 - 11:11 PM.
#3 danie garry
danie garry
    I love BMW minis
  • 2,296 posts
Posted 22 November 2009 - 12:20 PM
if you're using the refill can and sprayer, just turn the nozzle a bit to change it to a mist or whatever way u want it, if u get it to spray a fine mist u can barely see that its yellow
