Z-cars Monte Carlo, Intercooled Hayabusa Turbo, Usa Edition
380 replies to this topic
#76 welderman
welderman
  • 330 posts
Posted 09 April 2006 - 11:24 PM
Bet it feels like Christmas all over agian. Enjoy. :-
#77 Monte Busa
Monte Busa
  • 681 posts
Posted 23 April 2006 - 04:12 PM
Mocked up the steering wheel controls today:
Wheel: Sparco 310F2SN
Paddle Shifter: PBS Engineering micro switch
Aux Buttons: Sparco
Wheel Spacer: Pelican Parts 32mm
The left and right built in buttons will be left and right turn indicators (don't want a stalk on this one). The two aux buttons will be horn (bottom right) and manual lap timer (bottom left. before it's all said and done, there will be another umbilical for the indicators and aux buttons. Also had to order some longer m5 bolts and other misc hardware from boltdepot.com to adapt to my quick release hub.
Oh and if anyone is wondering I'm really not quite THAT pasty pink...color must be off on the Sony Cybershot!
Cheers,
Monte
Attached File  DSC01811_small.jpg   147.17K   53 downloads
Attached File  DSC01810_small.jpg   155.17K   120 downloads
Attached File  DSC01813_small.jpg   162.48K   111 downloads
#78 STEVEBLACKER1960
STEVEBLACKER1960
  • 372 posts
Posted 23 April 2006 - 05:19 PM
fantastic!
keep up the great work!
#79 danny987
danny987
  • 120 posts
Posted 24 April 2006 - 12:05 PM
lookin good so far mate kool mini.
#80 Baldspeed Racing
Baldspeed Racing
  • 1,195 posts
Posted 24 April 2006 - 04:27 PM
Pure car porn..........thats all Im going to say. Love it and fair play
#81 Custom_Minis
Custom_Minis
  • 702 posts
Posted 24 April 2006 - 08:00 PM
Hi Monte,
Glad its all got there safe - now the fun begins eh...!!??
Sorry, I've not replied sooner. Had moved house and internet connection was lost for just over a month.
Les.
#82 Willie
Willie
  • 66 posts
Posted 24 April 2006 - 09:13 PM
Went and picked up my Zcars front subframe and saw this " Spaceframe" car....WOW !!! Way good stuff here....I just wished Chris had these when I bought my Zcar project...This in my opinion is THE ONLY WAY TO GO....It's one sweet A$$ ride....His neighbor's are going to get a big kick out of this Beasty screaming around as well as the popo in town......
Willie.....Willie....Willie.....
#83 grey54321
grey54321
  • 59 posts
Posted 02 May 2006 - 07:49 PM
Hey Monte
I'm new to these forums and have just read through the whole of your project article. Its looks fantastic, everything is just, mind blowing.
Just wondering whether you have got any further along with the project, as I can't wait to see the end result.
Dan
#84 Monte Busa
Monte Busa
  • 681 posts
Posted 03 May 2006 - 01:53 AM
Progress is slow, but steady. Right now I'm sorting the tires on the wheels and trial fitting the arches, doing some seating and wheel position tweaks and working on building an engine stand so I can install a new baffled wet sump and remote filter system to the Hayabusa lump...
Cheers,
Monte
"Just wondering whether you have got any further along with the project, as I can't wait to see the end result."
Dan
#85 Mini_Rad
Mini_Rad
  • 20 posts
Posted 03 May 2006 - 11:46 PM
Thats just pure sexual! :proud:
#86 Monte Busa
Monte Busa
  • 681 posts
Posted 13 June 2006 - 01:40 AM
Quick update - been working on the 'busa lump.
First pic is Downs Engineering http://www.downsengi...m/hayabusa.html windage tray / baffle for their bespoke wet sump showing shortened oil strainer and breather tube, as well as higher pressure regulator. Need to lift the clutch out to install a matching high volume pump gear:
Attached File  windage_baffle.jpg   184.94K   99 downloads
Second pic is installed Downs Engineering sump from the front, showing oil out (on sump) and return (Aeroquip -8 fitting where stock filter would normally go). Blue rag plugs bypass hole, which I'm welding up a new plug for.
Attached File  front_pan.jpg   194.59K   119 downloads
Third pic is installed sump from the rear
Attached File  rear_pan.jpg   173.21K   41 downloads
Last pic shows dry fitted headers and collector which are being sent to HPC tomorrow for inside and outside coating. I'm thinking of going for their "extreme" heat control option http://www.hpcoating...at.aspx#extreme to reduce under hood temps as much as possible since my bum will be just 4 or so inches from the headers on the other side of a thin ally panel...
Attached File  exhaust.jpg   191.9K   39 downloads
More later.
Cheers,
Monte
#87 SeiPokGuy
SeiPokGuy
    Starting My Mini Up
  • 1 posts
Posted 20 June 2006 - 07:00 PM
Loving all the detail you put up with the build!! What color do you plan to paint the car????
How much power you predicting??
#88 Monte Busa
Monte Busa
  • 681 posts
Posted 21 June 2006 - 03:35 AM
...Just trying to keep everyone in on all the (tediously slow) excitement.
Right now I'm planning Silver with black accents on the body, black accents on the interior with red belts and other bits just to mix it up a bit. Right now I'm predicting about 185BHP at the crank with the mostly stock, but slightly tweeked, motor...I may have an induction surprise coming for everyone that might boost that number a bit...stay tuned.
Cheers,
Monte
#89 gizmo
gizmo
  • 132 posts
Posted 21 June 2006 - 03:44 AM
http.www.ignitionmagazine.co.nz/viewcargallery/70/1 nice looking mini with silver/black color RichMk1
#90 Monte Busa
Monte Busa
  • 681 posts
Posted 21 June 2006 - 09:51 PM
Good find - Oh My! A little OTT, but does give a guy some ideas, dunnit?
Monte
    Bing (1)
