Z-cars Monte Carlo, Intercooled Hayabusa Turbo, Usa Edition
380 replies to this topic
#286 Willie
Willie
  • 66 posts
Posted 03 November 2009 - 02:12 AM
i'm going to get ya this summer...snicker snicker...might need your rims and skins this weekend for fit concerns yes...
#287 Monte Busa
Monte Busa
  • 681 posts
Posted 03 November 2009 - 03:08 AM
Hey Willie,
Give me a holler - rims and skins are YOURS! I'll be here this weekend too, so call me any time 248-761-6614 (cell) or 248-446-0914 (home)!
Aric
#288 ChristianS
ChristianS
    Just On Tickover
  • 5 posts
Posted 16 December 2009 - 02:40 AM
any updates??
#289 Chris C
Chris C
  • 212 posts
Posted 18 December 2009 - 08:03 PM
This is one of the most serious minis I have ever seen.
#290 Monte Busa
Monte Busa
  • 681 posts
Posted 22 October 2011 - 02:15 AM
I've been slogging away on the project this past summer - too busy to post, but I'll give you a taste of what has been going on. Dry sump, 380BHP at the crank at 18PSI boost!
Attached File  P1010001.JPG   80.42K   143 downloads
Edited by Monte Busa, 22 October 2011 - 02:16 AM.
#291 koss
koss
  • 1,399 posts
  • Local Club: The Greenbank working mens social club
Posted 25 October 2011 - 11:02 AM
Looks like Im going to have to get the duster out <_<
#292 benpopham
benpopham
    The Carbon Weezel
  • 1,149 posts
Posted 25 October 2011 - 11:04 AM
WOOOO cant wait to see some progress Aric!!
#293 KTM kid
KTM kid
  • 227 posts
  • Local Club: Crews missels
Posted 01 November 2011 - 01:14 AM
Thats so sweet,
#294 BigDave99
BigDave99
  • 186 posts
  • Local Club: NA
Posted 01 November 2011 - 12:37 PM
Love it, very jealous
#295 Monte Busa
Monte Busa
  • 681 posts
Posted 25 December 2011 - 05:16 PM
Initial dyno tuning of the rebuilt lump. Running a Vi-Pec V44 with full boost control. We had some issues with boost spiking and compressor cavitation as the waste gate actuator spring was WAY too stiff. We're going to change injectors to an upgrade Bosch spec too, and start again in the new year.
Edited by Monte Busa, 25 December 2011 - 05:16 PM.
#296 Birdman
Birdman
  • 400 posts
Posted 27 December 2011 - 12:38 PM
Aric, in one of your posts you mentioned hoping to pull over a full G of cornering force. I suspect you will be able to do much more than that. I have a 4 axes G meter in my Mini and at the Mini Meet West this June I was pulling 1.68 G's of cornering force with my Mini.
#297 Monte Busa
Monte Busa
  • 681 posts
Posted 31 December 2011 - 07:30 AM
agreed, especially now with the slicks and all the aero goodness.
#298 Monte Busa
Monte Busa
  • 681 posts
Posted 01 January 2012 - 09:37 PM
Dust it off Koss and get to work!
Edited by Monte Busa, 01 January 2012 - 09:37 PM.
#299 Johanmini
Johanmini
  • 79 posts
Posted 04 January 2012 - 10:08 AM
hi Aric,
Nice project you've got there.
When looking at you enginge pics I see the internal waste gate right in front of your manifold. I don't know about the internal types, but I had this High temp Turbosmart external one, of wich the internal diaphargm melted in just 100 miles...and it's has more distance from the manifold as on your setup. I solved it by buying a newer type with a better diaphragm and wrapping/coating the downpipe. (only the manifold was wrapped at first and my downpipe goes the other way around, so this was very hot too)
How many PSI are you planning on driving it? Are the internals still stock?
And what is the blue thing on the left, which seems like the oil lines are connected too?
#300 Monte Busa
Monte Busa
  • 681 posts
Posted 04 January 2012 - 05:58 PM
Hi Johan,
Thanks for the compliments.
The Garrett internal wastegates are bulletproof, I'm not too worried about it. I'll be running 15 to 18PSI with 350 to 380BHP. The engine internals are far from stock - it's got Carillo H beams, CP forged low compression pistons, Cometic head gasket, ARP head studs, intake cam / exhaust cam swap, upgraded valve springs, adjustable cam timing gears, Vance and Hines high spec Hyvo timing chain, a billet race clutch, oversized output drive shaft, undercut race gearbox and shifting shafts, a full dry sump oil system, and a few more bits and pieces.
I'll be coating the header and turbo hot side with Swaintech ceramic coating, and also adding a turbo blanket to the hot side to reduce under bonnet temps.
The "blue thing" is a billet oil filter that feeds the dry sump system. It's made by Canton. You can see it here:
https://www.pegasusautoracing.com/productdetails.asp?RecID=185
hi Aric,
