After that confidence boost I went onto much more complicated stuff, starter motor, two bolts
Then decided to trial fit the alternator and exhaust manny using the allspeed bracket for clubman/extended roundnoses, next two pictures are for people that dont know what it looks like, the top part uses the original holes for the power steering assembly, not sure what the bottom original holes were for but more importantly I dont care
Exhaust manny, I still gotta buy the rest of the pipe from the manny, but just wanted a money shot!
You can see how much the alternator sticks out, front brace bar is for standard roundnose, manny is obviously custom for roundnose, gives you an idea of why people say "vtec? standard roundnose? NOOOOO!!!!!"
Fed the throttle cable through, but didnt hook it up yet, this is standard honda which has been extended for just the right length for a super smooth response
Then tried the alternator plug as it has been known to sit waaaay too close to the manny, yep, check
Simple solution, chopped of a lug on the tab, still clicks in and comes off if needed
The engines gonna move about when on the road so may wrap up the manny pipes still, will see
Sorry, I know I'm going into silly detail stuff here, its only for people that are not sure on these builds and gives them a heads up of usual build probs
Chucked on the old manky clutch slave cylinder, got a new one here but just wanted to see for myself the clearance issue you get with these and the standard front brace bar hitting the bolts
Slave cylinder will need to be drilled out for some M-8 countersunks to get.....
So what to do next? Well I'm dreading two things on this build, electrics and bodywork, so decided to hit the electrics first, I really dont know squat about electrics, I like to complicate it for some insane reason, so started with feeding the original mini loom back through the ridiculous little hole I cut out in the bulkhead. I mean why retain the original shape hole? For starters its not even in the same place as before! Idiot!
Considering there was relays, inline fuses and god knows what else in there I somehow managed to get the lot through
Then plug it up as before
Still got the DTA wiring loom to pass through!!! Doh! Idiot!
Started taking the mini loom apart
