This is insane.
I love it!
You'd have to be insane to do it in the first place! But cheers
Hows it all progressing ?
Slow as I haven't had as much time as I'd like on it, but to be honest I'm just daubling on it as and when as I'm more than happy at the moment to let other things (life!) get in the way as although the car is far from done cosmetically it has been driven here there and everywhere so its got nothing to prove on the getting it on the road front
It will be finished eventually
In the meantime I might aswell throw in a little update for what its worth
The car has been laid up for about 4 months, last time I used it was in september at the rolling road which was a couple of weeks after getting back from Germany, at the rolling road the rear silencer had fallen off! so that was obviously one thing to sort out and also had a pin hole leak from a CV boot gaitor so these things needed sorting out first
Before all that I just wanted to make sure it still started up using 3.5 months old worth of fuel, battery was showing 9.5V so quick charge and it started first key
Coolio
Started off with taking the driveshafts out, both didn't need to come out but you know what its like...
Had a bit of trouble getting the hub off one shaft so took the whole lot out to investigate why, after some help from this forum it looked like some water had got in and and caused a bit of surface rust which made it difficult (thanks tiger99) so quick clean up and back together
Then the rear silencer falling off bit...
The night before I took it to Germany I was still welding up the front section of the link pipe but still had a few pin holes as I could feel it blowing out but as I was out of time I just ran it like that, it felt slower than before but it got me there did a couple of laps and got me back, when I got back I found the pin holes and welded them up, car was running good so then took it to the rolling road a couple of weeks later
The rear silencer was being held up by two powerflex hangers and when the middle silencer was added it looks like the additional weight of the middle silencer ripped both hangers apart. I'm just lucky the hangers ripped and dropped the rear silencer at the rollers and not at the 'ring a couple of weeks beforehand as the middle silencer was added quite a while ago
I wasn't too worried about the rear silencer dropping as I had a flexi section up front so nothing was getting stressed apart from that flexi as thats what its there for, but when I started the car up I could see some 'dust' being moved on the floor under the car so went to investigate and found some 'puffing' coming out from the flexi section
Dropped the whole exhaust off as one and lifted the front manifold gently, before it would rise with some resistance from the flexi (a gentle bend) now it was lifting loose and you could feel it kinking - looks like the flexi got too stressed when the rear section fell off
Not much I can do to repair it so I'm gonna lose it, so chopped it off (the cut in the flexi is what I done after it was on the bench)
Luckily when I put the middle silencer on I kept the link pipe section I cut off, so this will now be used to join it up, bit of jiggling and it should be fine
No major plans for the car at the moment as it looks a state on the outside and needs a respray, would love to try and get this exhaust on and at least try to take it to Brooklands as I'm itching for a drive but we'll see
