Rio-Tec (Aka Demoraliser) B20 And Rovers Finest Steel Wheels Equals
1065 replies to this topic
#856 Kam
Kam
    Straight to the Point
  • 4,140 posts
  • Local Club: 16vMini club
Posted 23 May 2012 - 08:07 PM
As usual I've left the wiring for another day, I know wiring up the removable front end aint difficult but I really do hate it with a passion...
So thought I'd have a stab at the bodywork to at least get it ready for the front end wiring, driver side headlamp is a bit on the close side, its the best I can do, so got about 5mm to the radiator fins! :lol:
The front grille was doing my head in, after all that flapping about cutting some slats down it leaves a bit too much on show, so now when the sun hits it the radiator and exhaust manifold shine up! - stealth fail! >_<
Monkey to the rescue! Picked up a couple of bits from him few days ago and he gave me a front grille that he had lying around that he cba to sell, I didn't really need it as I was working on my current one but had it anyway, today I needed it, cheers again :mrcool:
I'm gonna cut that driver side shielding away but I can actually leave the slats as they are, looks like when I last messed around with the radiator position I managed to grab a few more mm clearance, rad to slats is about 10mm now, plus it covers up where necessary so hopefully back to stealth again (bonnet just laid down)
Well stealth anyway when the bottom blue bits of the subframe are anything but blue!
MOT is booked up for tuesday....
#857 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,724 posts
  • Name: Chris
  • Local Club: None
Posted 23 May 2012 - 08:18 PM
keep it up matey its looking good, would really love to have a butchers at this in person someday, maybe when mines on the road
YetI
#858 Kam
Kam
  • 4,140 posts
Posted 25 May 2012 - 09:54 PM
Finally started on wiring up the front end
Never mind the blanket, it was a xmas gift for me but I kindly donated it to the garage floor, I'm very kind like that you know
Anyhoos, took me 4 hours, must be a record for me, dear diary moment and all that...
Quick (very) vid
As I'm not using the drivers side under wing space now I'm gonna try and mount my radiator overflow/expansion bottle there as its the only space left, obviously the honda OEM overflow bottle is larger than vanessa feltz so needed one more suited to the job, popped down the breakers and found one, I won't tell you what its from as thats a secret
I should be able to get the inlet pipe level with the main rads outlet pipe, only problem is the inlet pipe is at the bottom and the overflow pipe (for the overflow bottle!) is at the top, so will block up the top pipe and do some hoseage work with the bottom one to get it as level as poss, oh and the inlet is 25mm and obviously my rad outlet pipe is the normal 10mm, so will be interesting but should work still fine, he says
Also picked up a scrap bonnet so I can salvage the safety hook in the corner for my bonnet
Only problem is apart from maybe off centre there aint much 'inside slam' panel for it to catch :lol:
'tis a nice blanket
Worse case scenario I'll weld it to the bonnet so it hooks up to the side section of the wing?
MOT guy says it needs a safety hook, so be it, at this point he's holding the cards, so if he says go jump off the white cliffs I'm there
Next job - go find some low level cliffs as I'm scared of heights
#859 Kam
Kam
  • 4,140 posts
Posted 25 May 2012 - 09:57 PM
Cheers mate, I'm missing out on shows here so do want it on the road ASAP, also because I haven't driven a mini properly for about 18 months :(
#860 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,138 posts
  • Name: Sean
Posted 25 May 2012 - 10:03 PM
Looking good dude!!
If theres no room for the safety catch would your MOT guy accept a safety chain?
#861 Kam
Kam
  • 4,140 posts
Posted 25 May 2012 - 10:46 PM
Probably would Sean, I know you mentioned this before but I was worried about the rattling when on the move, the things I worry about....
#862 Shifty
Shifty
  • 13,138 posts
  • Name: Sean
Posted 25 May 2012 - 10:47 PM
Cover the chain in plastic tube!!
#863 Kam
Kam
  • 4,140 posts
Posted 25 May 2012 - 11:37 PM
Interesting, intelligent and a bloody good idea!
If I have trouble getting space for the hook I'll try that instead, if the MOT guy says anything then I'll throw HIM off the white cliffs!
#864 BenH
BenH
  • 742 posts
  • Local Club: CV1 Minis
Posted 26 May 2012 - 02:43 AM
Must say, very tidy bay youve got. The rocker cover and inlet look brilliant. Looks like a factory build.
Cant wait to see this in person. Wish i had the patience to do a vtec build
#865 yeti21586
yeti21586
  • 3,724 posts
  • Name: Chris
  • Local Club: None
Posted 26 May 2012 - 07:58 AM
I think that the overflow bottle is from a 1.3 ford ka?
Am I right????
Do I get a prize or a medal or something????
YetI
#866 Kam
Kam
  • 4,140 posts
Posted 26 May 2012 - 10:47 AM
Am I right????
How the hell did you get that right? :genius:
There you go, I've liked your post, rare thing from me, thats your prize, savour it!
#867 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 26 May 2012 - 01:24 PM
I liked yours, just because I can!
#868 Spud_133
Spud_133
    mmm potato and cheese....
  • 1,689 posts
  • Local Club: C&T Classics
Posted 26 May 2012 - 01:28 PM
I liked yours because it made me smirk, Matt.
Living the work though Kam, the blue is beautiful :wub:
#869 yeti21586
yeti21586
  • 3,724 posts
  • Name: Chris
  • Local Club: None
Posted 26 May 2012 - 10:28 PM
I don't care what spud says but I'm loving your work kam!!! Oh and thanks for the like, I will treasure it!!!
#870 Kam
Kam
  • 4,140 posts
Posted 27 May 2012 - 07:18 PM
I was gonna 'like' that but this like biz-ness is getting out of hand, I blame Matt :lol:
