Rio-Tec (Aka Demoraliser) B20 And Rovers Finest Steel Wheels Equals
1065 replies to this topic
#61 captainjack15
captainjack15
  • 3,925 posts
Posted 14 February 2010 - 08:55 PM
Nice progress you've got there mate :)
#62 THE STIG
THE STIG
    Da stig says, GO GO GO
  • 2,506 posts
Posted 17 February 2010 - 09:42 PM
heres the sump kam
seen weld in baffle kits on ebay for £10
Edited by THE STIG, 17 February 2010 - 10:19 PM.
#63 Kam
Kam
    Straight to the Point
  • 4,140 posts
  • Local Club: 16vMini club
Posted 17 February 2010 - 10:16 PM
Sean, you are a lifesaver!
PM sent, much appreciated mate ;D
#64 RED HOT
RED HOT
    Fantasy F1 Winner 2011
  • 354 posts
Posted 22 February 2010 - 09:26 PM
Where did you get the ACT clutch / fly from? I could only find places in the states!
#65 Kam
Kam
  • 4,140 posts
Posted 22 February 2010 - 11:36 PM
Good 'ol Funky power Clicky
Been told though by some Crx lot that the blueprint clutch I bought has been known to squeak? So we'll see, the flywheel is ACT and meant to be spot on :D
#66 ginger_monkey
ginger_monkey
  • 1,080 posts
Posted 22 February 2010 - 11:50 PM
Most blueprint stuff is spot on so you shouldn't have a problem. Shouldn't being the main word :lol:
#67 Kam
Kam
  • 4,140 posts
Posted 28 February 2010 - 09:05 PM
Most blueprint stuff is spot on so you shouldn't have a problem. Shouldn't being the main word :dontgetit:
I've used blueprint stuff before and never had any problems, had a mr2 turbo running about 280 at the wheels with a blueprint clutch so hopefully this one can handle the pony power this ricer puts out :thumbsup:
Haven't done much really, been stuck on trying to find parts so got alot done this weekend but on paper (well screen actually :( ) it dont look like much! :) For some strange reason I started doubting whether I put any thread lock on the flywheel and clutch pressure plate bolts before bolting it all back up, not sure why? Have you ever left the house and gone back to make sure you locked the front door? Yep thats what I did today. back track and waste a day, one step forward two steps back..... ;)
Here we go again!
I was right - schoolboy error, no thread lock :) Maybe I should stick with something more straightforward? Like lego? :)
Took ages for some reason getting it all locked up, thought I might aswell add some gearbox oil while I'm here, oils been sitting here......
Mind you I did get my DTA ecu kit from Watsons come through, nice and cheap! :) This is the price you pay when you dont understand electrics and dont want to take a honda loom apart!!! I did say to geoff to put an idiot guide in there and label everything up, which he did, expect I still dont understand electrics after getting it through :(
Kit includes a ford DIS coil pack (so no honda dizzy for me) and my crank pulley which has been modified by geoff where he 'adds' teeth to the outside...
which hooks up to a pickup sensor which mounts on this bracket using the honda alternator holes
As usual progress is slow, at this rate I will be walking to Le Mans ;)
#68 Kam
Kam
  • 4,140 posts
Posted 28 February 2010 - 09:06 PM
Had a couple of bits I've been trying to source now without any luck, needed a replacement oil sump, not easy to find unless you want to drop off £242 to honda :dontgetit: also needed some inner cv's joints as I didnt get any driveshafts with my engine and they needed to be the right ones as I got the allspeed shafts, and there are multiple cv's about, great more headaches! :)
So my only saviour this weekend has been in the shapely form of The Stig from TMF, he had the exact bits I needed and he helped me out. Thanks again for this Sean really appreciated fella :(
He also welded in a baffle kit I sent him and sent the whole lot back
I found the circlips aswell mate ;)
Deadline is still june, got a couple of changes planned already to the build to give myself a 50/50 chance of finishing by then, as at this rate I'm gonna struggle big time, besides its been 3 months since I last drove a mini! :)
Need to get my finger out......from somewhere :thumbsup:
#69 HARBER07
HARBER07
  • 4,498 posts
  • Local Club: Naaa......
Posted 28 February 2010 - 09:21 PM
Looking good Kam :dontgetit: Which DTA did you got for?
#70 Kam
Kam
  • 4,140 posts
Posted 28 February 2010 - 09:29 PM
S40 Pro, I think its the only one Watsons use? I got track n road just across the water who can map it, he said he's done quite a few from watsons so roller time should be minimal.......pending on my electrical put together though! :dontgetit:
I'll be honest, I only bought this to get a pre made wiring loom in there, I really dont do electrics in any way shape or form! :)
#71 HARBER07
HARBER07
  • 4,498 posts
Posted 28 February 2010 - 09:32 PM
Ah i just wondered as I'm probably going DTA on my build too. I will also get it mapped at track n road as they seem to be the best when it comes to DTA stuff!
#72 xBR4DLEY
xBR4DLEY
    >>mine's still gay<<
  • 1,618 posts
Posted 28 February 2010 - 09:42 PM
Nice Mate
Whats your budget?
Do you want to sell me your old gearknob :)
Are you putting in Honda Clocks?
I dont reckon you will be able to take this to honda for a service will you :dontgetit:
#73 Kam
Kam
  • 4,140 posts
Posted 28 February 2010 - 10:07 PM
Whats your budget?
Do you want to sell me your old gearknob :thumbsup:
I dont reckon you will be able to take this to honda for a service will you :)
Budget? Depends on your skills? So I don't use one! Seriously mate, have a figure then forget about it, as in my case ;)
Knob? I'm gonna try and use it to fool my passengers when I go for fifth.....
Clocks? Plan is to use the standard mini 3 clock nippon setup, the rev goes to 8000rpm which is nice even though the speedo hits 110mph??? Again, if you get in my car, it has to look mini, not modified :dontgetit:
Service? The guys at my local honda keep asking "is it ready? pop it up, I want to see" If I can nab a free service from them for the first year then yeah I'll pop it up! :)
#74 ginger_monkey
ginger_monkey
  • 1,080 posts
Posted 20 March 2010 - 07:30 PM
Any progress with your build mate?
#75 captainjack15
captainjack15
  • 3,925 posts
Posted 20 March 2010 - 07:32 PM
Took the words right out of my fingers Chris! :D
I think he's too busy to post on TMF :wub:
