Rio-Tec (Aka Demoraliser) B20 And Rovers Finest Steel Wheels Equals
1065 replies to this topic
#706 Mini-Mad-Craig
Posted 28 October 2011 - 11:19 PM
This looks amazing mate! Some very posh bits there!
#707 Burnard
Burnard
  • 3,350 posts
Posted 28 October 2011 - 11:39 PM
do it pink. pink is cooooool. lol.
#708 Jamie_hail
Jamie_hail
  • 555 posts
Posted 29 October 2011 - 03:01 AM
Said it once mate, I'll say it again - very nice peice of kit! I'll have that bracket off you in a couple of weeks mate - almost got enough pennies spare to get a subframe so wont be long, might even talk mother dearest into helping out for a few weeks!
#709 Kam
Kam
    Straight to the Point
  • 4,140 posts
  • Local Club: 16vMini club
Posted 29 October 2011 - 09:48 AM
Haha no worries Jamie, the bracket aint going anywhere so no rush
Cheers Craig, the camera makes it look better than it does, or posh in your case
#710 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 29 October 2011 - 10:15 AM
When am I gonna get to see it then fella? :D
#711 Kam
Kam
  • 4,140 posts
Posted 29 October 2011 - 08:28 PM
God knows, I want to finish it and get it to Brooklands in march, I know its a bit far for you but you never know.......I might go for a little drive one day.......so you might see it :D
#712 Kam
Kam
  • 4,140 posts
Posted 29 October 2011 - 09:04 PM
Was hoping to paint the block today so chucked it on the stand, seemed a shame to paint over my name :(
Masked it up and then found I got no paint here anyway :-
Oh well, I thought I'd try something that was here, putting the inlet and fuel rail together
After doing some reading online it seems some people were saying that if your using smaller injectors like my RC ones you can't use the original spacers as the fuel rail will sit too high, by smaller I don't mean overall size just the mounting point for the rubber inserts in the inlet
I bought these injectors secondhand and luckily got a set of rubber inserts with them, original on left RC ones on right
I found not using the original solid spacers and mounting the fuel rail straight on wasn't gonna work as theres no thread for the nut?
Using the original spacer works fine and leaves enough thread after the fuel rail is on
You can see if you don't use the right rubber insert the injector sits too high
Even if you use all the high rubber inserts the fuel rail won't clamp down enough as its not sitting tight against the solid spacers behind
With the correct rubber inserts and using the original spacers it all fits fine
So if you get aftermarket secondhand injectors make sure you got the inserts that come with them
Mounted up my adjustable fuel pressure regulator and fuel pressure gauge
All done
Also been contemplating getting a small discreet Honda badge and graphic put somewhere on the car, thing is I don't want to give the game away, whaddya think? :-
#713 Kam
Kam
  • 4,140 posts
Posted 30 October 2011 - 08:56 PM
Decided to get this engine painted up so I could chuck it in the car as I need to get on with things but hit a problem :( see later
Put the gearbox casing back together, I know I only painted it black a couple of months ago but decided to paint it again - as you do!
Then threw some on the block
Its funny how its come up looking like a nice job with the aid of a camera :lol: I just grabbed a paint brush and did a splash n dash, a wham bam thank you Kam kinda job :D
Then the problem, I can't put it back in the car as I haven't got my flywheel here! He forgot to put it in with the all the stuff, it was given to him to reface as it had about 2000 miles on it, it must be still at the machine shop, I still need to pick up the head so back to waiting now :( not good
The aero hose for the VTEC supply was bothering me whilst I was painting around there.......I need to fit a 3 way union so I can fit all my oil pressure/temp gubbins plus that oil pressure switch that is already in there, I started wondering about the water pipe that runs around the back as it has two pipes coming off it, one goes to the factory oil cooler on VTECs and the other goes to the Idle Air Control Valve
The B20 doesn't have this oil cooler on the back hence the oil filter sitting smack bang up against the block, heres an old pic of my B16 with the cooler, filter then goes on top
You can see it goes from the back water pipe into the top of the cooler then out again and into the block to the water jacket around the bores, I doubt it does much anyway I mean its only a small thing, but I suppose its better than a kick in the nutsack :wacko: its gonna save me some bulkhead space anyway......
I'm not trying to teach people here how to suck eggs, just explaining for the ones that don't know as they were probably expecting a normal row cooler
I need to do away with those two pipes sticking of the back water pipe as they get in the way of my 3 way I need
I don't need the oil cooler outlet pipe (see above) or the IACV one either as I'm using a DTA which ditches the IACV, so as my good friend Mr Patridge would say - back of the net!
So I now gotta do something about this pipe and chop off both outlets
I think its ally and I only got a MIG here, maybe a couple of small plates and some pure argon might work, but I think I'll pop it down to a local place and get them to do something, then wait for them to sort that, not a fan of waiting for people now......
#714 Burnard
Burnard
  • 3,350 posts
Posted 30 October 2011 - 10:20 PM
make sure it is ally before u send it away...
Block does look good, but its not pink :(
How about 'I stole my engine from your grannies car' or 'Its gonna kick in, YO! ' ?
Edited by Burnard, 30 October 2011 - 10:22 PM.
#715 Kam
Kam
  • 4,140 posts
Posted 30 October 2011 - 11:39 PM
I
I might just do the Top Gear one and get a big Rover badge and take out the R :-
#716 paul190181
paul190181
  • 193 posts
Posted 31 October 2011 - 12:39 PM
Looking realy good kam , its going to be one hell of a nice motor , Need to get on and do a bit more on mine soon ,
#717 Kam
Kam
  • 4,140 posts
Posted 31 October 2011 - 01:01 PM
Cheers mate, yeah you seemed to be cracking on with yours at a good pace then it kinda stopped, it happens though
I'm at a standstill again until I get my flywheel back, I was all pumped up and ready to hit it again big time when I bought the block home and now I'm waiting again......not good, I hate being on standby.....
#718 paul190181
paul190181
  • 193 posts
Posted 03 November 2011 - 12:42 PM
Yeah i was cracking on prety well then my daily driver decided to brake down big time and cost me a fortune and the pennys are a bit tight at the mo so rather than try do bits on the cheep i just thought id leave it for a while . cant wait to see yours going , get some inspiration to crack on with mine .
#719 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 03 November 2011 - 12:59 PM
When am I coming down for a weekend with the spanners? :P
#720 Kam
Kam
  • 4,140 posts
Posted 05 November 2011 - 12:39 PM
My hut is quite small and your quite tall so I don't think you'll fit :teehee:
I'm currently only watching paint dry, no spannerage going ons at the moment, if all goes well I should pick up the head and flywheel next week and can finally crack on, hate stopping n starting.......
If I get stuck I will put out a cry for help on here though, I might have done the 1.6 all by myself but that doesn't mean I won't ask for help if needed :thumbsup:
