This is a silly update so don't expect anything amazing (like you ever do?) I haven't really been doing much on the car, not being able to go to germini kinda sucks so its all at my own pace now. The engine, exhaust and custom rad are all being built so I thought I would take the time to get on with all the other little jobs in preparation for them, but its hard to work on a car that don't really look like a car if you know what I mean? Its a kinda naked body!
First up I decided to tidy up the wiring in the engine bay, it needed to be tidied up anyway but also needs to be redone on the front end as before I had it wired up for the clubman front using these awful useless so called waterproof multiplug connectors that were anything but waterproof! I'm gonna try the good 'ol caravan plugs now, seen them on a few TMF cars so will give that a crack
Unfortunately after laying all the bits that needed cutting/trimming/tidying up
I packed them away and decided to tackle it another time! I really hate electrics
So I tried something I'm more comfortable with - driveshafts!
New gaitors and new steels bands and some new grease
I double wrapped the steel bands and put on a "I'm comfortable with this amount" of tigerseal aswell, bit OTT, just the way I like it, the small inners just got plastic ties, the main issue with the crazy angle these sit at is the large outer pot, other frames might get away with no issues but more than one has had problems on the allspeed ones.....my advice......tigerseal, proven
I dare these gaitors to come off, I dare them........
Got some paint on the brake master
And sent off my brake servo to be powdercoated to the same guy who done my skunk2 inlet and rocker cover, there was some issues getting this actually
powdercoated though as there was what seems like something inside the center which might have melt, we agreed not to pull it apart so he painted it up for me in the same colour, also got a recently shot blasted/painted up servo bracket to replace my manky one - cheers Steve
Another day another helpful forum member, I needed some 'bits' not the sort of bits I can make or buy from tescos, I'm talking proper bits!
My alternator bracket has an already slotted cut but I needed it longer, it also had strangely one mounting hole (for the main body bolt) bigger than the other, I also needed a spacer plate for my AP 14mm clutch master of around 8mm and another small spacer for my alternator idler wheel and a securing bracket for the alternator itself, from my conclusion this stuff is not available from tescos? luckily Adam was a godsend here
Cheers again mate, you helped me out of a pickle big time as I was proper stuck!
Next was the whole rear end, its pretty much done so I thought I'd torque it all up and and chuck the rear wheels on, bar the exhaust theres nothing to do back there, only problem was I found one of the bolts on the rear subframe kept spinning by hand!!!!!! Had a small moment of panic as I thought it was the bolt that holds the subframe in the captive nuts in the bodywork, luckily it was the bolt that holds the KAD right angled bracket to the subframe, the one which holds the radius arm in situ, if it had been the other one - the captive nut behind the heelboard, well you know what that would've meant - me crying in the corner! I would've been truly stuck
Whichever one it was it meant one thing - taking the rear subframe off again!
Two hours on my own which was a personal best and a dear dairy moment for me
The offending spinner! Top center
The 5/16 bolt goes in well but spins after a short while, the thread is goosed a 'bit' on both so I'm gonna weld on another nut on top of the current one, there is plenty of room (not for a welder!) before it starts to interfere with the main bolt of the trunnion
On a plus side I got my buddyclub Kam gears through to go well with my buddyclub Kams, so all should be sweet on the Kam front
Next job - you decide! I don't care, I'm at that 'stage'
