Got a few days off work so trying to get done what I can, unfortunately the pistons are gonna take a few weeks as I think they have to be made, I still need to drop off my block and head to get some work done on it aswell, and find a place who can shot peen my rods, all takes time
In the meantime, I found the cam side mount holder on the B20 is the exact same as my B16 (two studs), the B18 has three
Also the bottom plate from the B18 fits nicely on the B20, all interchangeable stuff. My B16 didn't have this plate, it really is a godsend when taking off or putting on the gearbox on your own as it keeps the engine level and at the right height
So I chucked my old gearbox on just for a pic really
Then started on the suspension, I got a new set of hilos and obviously some red dots, these red dots are little bit taller than standards so getting them in was a PITA to say the least, but got there
I also spaced out the bump stop, so tyre contact on full lock at the same time as full drop should prevent any contact - I think!
I bought some minispares top arm refurb kit last year so the top arms should be fine to reuse, I will take them apart though and clean the lot up, would be rude not to
The frame is also now finished, drilled some holes and got some high tensile bolts and whacked them on an welded up each end of the bolts and slung some paint on
Yes I know its OTT as its already been welded but this frame now has no warranty so its all on my head - and I'm a belt n braces type person
Finished up the front bar aswell, chopped out a very small section and plated it up and duly threw some paint on
The above is just preventive maintenance as the manifold will sit close depending on final engine clearance.....
Also got a new OEM oil pump, getting a B20 one is pants as they probably don't work at high revs so this one is for a 1.8 type-r, local honda wanted nearly £300! Got this for just under three figures inc delivery from taiwan!
I know someone who can take it apart and check its all fine so no worries there
Also I needed some valve stem seals, Honda UK want about £8 each on these! so by my calculations for sixteen thats around £128? So I got them
for $60 inc delivery from our friends across the pond!
Sort it out Honda, its only for a mini!
