It only just has enough clearance
Incase anyone is wondering why the pulley is there, its because it clears the back part of the frame it was designed for, lucky for me it also clears (just!) the back inside corner bracing of the allspeed!
So the alternator belt travels as below as it would do on the MTB frame
It looks tight where they meet and it probably is, but its not set in stone yet, so it might clear or it might not, the belt clearance where its sits close will be the same no matter what frame its used on, the only problem is whether the belt clears the corner brace on my allspeed? I can always change to a LARGER pulley to clear the corner bracing on mine but this will make the belt hit in the middle, and changing to a smaller one will keep the belts apart but will send the belt into the corner brace? Simple eh?
No biggie though, I was feeling in a good mood today so I decided to come up with a Plan C extension!
Plan C extension is the the two holes at the front at the top of the head (for the honda power steering pump)
which are now not in use on mine as before I had the front mounting kit for the alternator there before so I decided I'll make up a plate and weld on a support bar to house another pulley like so (using previous pulley for reference)
It'll be tucked in neatly so it clears the underside of the wing, then the new back up belt will run as so
I reckon it'll work fine
My deadline for taking this to Le Mans in June will probably not happen now
I will try to get this completed in 3 months but if it don't happen then it won't happen, but I won't push it like before as I've been there done that and didn't like the outcome back then......
Next job some more project fuel for me - Kams Favourite Chicken
